Impact Wrench
Old Dec 13, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Impact Wrench
If I were to buy a electric impact wrench to remove and put rims/wheels on . What kinda things should I look out for. I don't want something that is tooo powerful that I will screw up something, but I want something that will be able to remove the nuts.
Any brand name or modle that you guys use???
Old Dec 13, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
A lot of people use the cheap **** ones from Harbor Freight because ALL of them suffer from the same issue.... they suck *** and break no matter what. None of them have enough power to cause damage, but make sure you have one that can bang at least 110 lb-ft, if not more.
Honestly, spend $25 on a 7.2V cordless drill, crack off and torque on the lugs yourself with a wrench. Its safer than trying to impact them on.
Old Dec 14, 2005
streetglower's Avatar
the ones from harbor freight are ****. I purchased one that said up to 330 lb. ft of torque and it would take about 20-30 seconds to remove the lub nut if even at all. I used it once, then put it up on ebay for $1. its easier to use the bar that comes with the car.
Old Dec 14, 2005
PennyKnotOff's Avatar
Just don't buy an impact gun to remove and install wheels........
Old Dec 14, 2005
Nick's Avatar
Formerly 2blu
I bought on from autozone for $70. It supposedly puts out 200 ft/lbs. Its worked good for 2 weeks, and i used it to take off my suspension. And if it breaks i got a free lifetime warranty.
Old Dec 14, 2005
mrDFWmechanic's Avatar
i use my trusty craftsman torque wrench i barely use air tools
Old Dec 14, 2005
skipbarber's Avatar
i use my dewalt 14.4v impact to remove things only. I torque everything manually.
Old Jan 11, 2006
Eclectic's Avatar
Eclectic is an unknown quantity at this point
sorry to ask but are impact guns and impact wrenches the same? oh yea, are they necessary in installing an AEM pulley?
other than that, what's a good soldering tool? does that cold heat thing work?
Old Jan 11, 2006
Jap-Euro Fusion
yes, guns and wrenches are the same thing.
This isn't the place for pulley installs
and soldering is a completely different subject all together, once again, somewhere else.... but if you're gonna solder, use a hot iron or gun.
Old Jan 11, 2006
most likely yes those pulleys are on tight.
Old Jan 11, 2006
XxSoVeReiGNxX's Avatar
dont forget to buy IMPACT SOCKETS! if you use regular (silver/chrome) sockets, they may explode on the gun
Old Jan 11, 2006
juzthewy's Avatar
juzthewy will become famous soon enoughjuzthewy will become famous soon enough
lmao @ imagining an impact wrench exploding
ken4444
Sep 30, 2015 07:37 PM
Bruce2
Sep 21, 2015 08:01 PM
stank
Sep 16, 2015 07:40 AM
Wiggles
Sep 8, 2015 05:05 PM
WaryDriver
Aug 8, 2015 05:08 PM
