15x7.5s for less than $300?
I'm aware of 4 so far.
Volk makes one, SSR makes one and Work makes 1, Enkei makes 1
All of which are more than $300 per rim...
Has anyone come across a 7.5 in the $200ish neighborhood? I'm expecting a cast rim, but thats not my issue. I'm aware of 1 15x8 with a 4x100, but it was a limited run for Miatas, the offset isn't right.
I thought SSR went out of business and you forgot to mention ROTA also, so far i've had no luck finding any under 300.00 per wheel especially being forged I'll look around some more and post back on what I can find
Saludos de Puerto Rico !! I'm thinking about getting SSR semi-forged 16x7 11Lb at tirerack just because 16x7 at 11.0 Lb sounds pretty light considering my actual steel 14" factory wheels and also trying to counter size with weight so car wont suffer that much. But is $329.00 a little to much ??
Ummm the relevance to this thread is what?
Anyways. SSRs are notorious for becoming eggs if you drive them hard. So plan on buying a lot of them. The Semi-Solid forging is a bit of crap when you compare it to honest to goodness forging, so I don't particularly care for SSRs, not to mention they're on the verge of non-existence due to legal problems so getting replacements may become difficult.
was getting your advice on my issue
deanaZoom
35
Sep 19, 2015 12:22 PM
