Purpose of outer pad shim?
Old Oct 19, 2005
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
What is the purpose of the outer pad shim on the outside brake pad? This seems quite un-necessary and I'm thinking they are adding it just so there's another part you have to buy. It seems that if you remove the shim then the caliper has a gap, thus it wont be a good idea to take it out. BUT, it should have been designed without the shim in the first place. No?
Old Oct 19, 2005
ncirom2003's Avatar
the shim cant cost more than a dollar, just throw a freakin dollar down and get them, otherwise you can re-use the old ones if you really want.
Old Oct 19, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Its there to keep the pad backing straight and to keep the pad centered in the clips (hence the tangs on the shim), not to mention its another heat barrier between the caliper and the pad backing.
They can't be more than a couple bucks each and theres no reason not to reuse them.
Old Oct 19, 2005
tfnaaf's Avatar
BLDNPSI Mod
Shims are there to help reduce brake noise by isolating the vibrations
Old Oct 19, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
he's got it right. the shims are used to eliminate noise and vibration (altho at work i dont put them in cause it takes extra time to stick em to the brake pads, and they get annoying) by the way, dont take your cars to pep boys
SammySC
121
Apr 7, 2017 07:43 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
sf3r8z
Sep 23, 2015 03:26 PM
