I broke stud on my front hub! please help
Old Oct 17, 2005
mrb420's Avatar
mrb420 is an unknown quantity at this point
Well somehow, I broke one of the studs on my front hub assy, trying to remove the lug nut. I did a search and bought the Haynes guide, but I am still having trouble removing the hub assy. I want to remove the circle piece holding the studs, so I can bang out the broken stud. I found a parts diagram that shows what looks like a snap ring, as part of the assembly, but I can' t see that ring on my car. My friend said, on his car (American made), he could just bang the hub with a mallet and it would pop off.
Does anyone know how to remove the hub assy?
So much B.S. just for a $1.99 part install. ...
Old Oct 17, 2005
mrb420's Avatar
Isn't there anyone who knows how to fix this problem?
Old Oct 17, 2005
orion_squall's Avatar
follow the rotor removal DIY, and then once the roter is removed it will be all clear to you.
By the way, samething happend to me before, 35$ to ask store to do it include parts. So I say let store do it.
thanks
Old Oct 17, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
eh, careful wit banging it out, u might have to buy a new hub bearing. u could use some sort of press to get it out tho
Old Oct 17, 2005
streetglower's Avatar
you cant just knock out the stud on the front, you have to remove the hub assembly to do so. If you notice, the stud has no clearance behind it to remove it. You basically have to remove the knuckle assembly and press the hub out of the knuckle. Unless you have a hub remover or press and a impact to remove the axle nut, you need a shop to do it. There are tools to remove the hub assembly while on the car, but they arent cheap. it will usually cost around $75 to replace a stud on the front due to the labor involved.
Old Oct 17, 2005
Overboost's Avatar
Overboost is an unknown quantity at this point
Honda dealership quoted me for $45 for the removal which i'm doing in 2 days
Old Oct 17, 2005
thats pretty good if they are charging $45. with the amount of work to do just to remove the stud, thats good. Is that for the front though?
Old Oct 19, 2005
LiKEaFeRiO's Avatar
Yeah its not as easy as it is on other cars.
I ending up paying $40 to get it replaced (and the shop used OEM Honda sutds).
Old Oct 19, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I just did the same friggin thing, Im just gunna take the knuckle off and bring it to honda. What a pain in the ***. Note: When taking off lug nuts, dont leave your 500 ft-lb impact wrench on forward at full power to take of the lug nuts. All I did was touch the frigging trigger for like 3 seconds and it broke right off. hehe
Old Oct 19, 2005
xDCx's Avatar
those of u who replaced stipped/broke studs, do u now get squeaking noises coming from it? if so howd u fix it.
Old Oct 19, 2005
no. Did you install everything properly?
Old Jan 16, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
wut kinda studs does our Vics got? And wut issues does a broken stud cause?
YEa yea i know old thread..... but y start a new one.
Old Jan 16, 2006
J Smith's Avatar
J Smith is an unknown quantity at this point
could always pm him
Old Jan 20, 2006
djmota's Avatar
if you are getting a squeak after someone fixed a front stud, the wheel bearing is bad and you need a new one. Thats why honda recommends a new bearing when the hub is taken apart. Some can get lucky and reuse the old one but not all.
Old Jan 22, 2006
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I had to have a stud replaced today because my horrible dealer cross-threaded my lug nut and then air gun'd it on. I took it to another dealer in town and they replaced basically the whole assembly, and sent a bill for $300 to the dealer that screw it up in the first place. I'm happy, I can remove my wheel from my car again.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
BootyDo
Jun 21, 2016 03:45 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
AaronSorenson
Jul 7, 2015 09:40 PM
bsmiley
Apr 27, 2015 01:27 PM
