My car is pulling hard, to the left, Please Help!
Old Oct 14, 2005
mrb420's Avatar
mrb420 is an unknown quantity at this point
Ok, I tried to search for solutions to my problem, but the search page is not working for me. Anyone else experiencing this?
Anyway, I recently rotated my tires according to the manual: Put each rear tire into the front position, same side, then take the fronts and switch them to the opposite rear sides. Now, my car is pulling hard to the left. I really have to keep the steering wheel positioned so that I don't drift into the other lane. I checked the pressures-OK.
I thought maybe the alignment might be screwed up, but I have rotated my tires many time before without isssues.
Does anyone know what the problem is?
Old Oct 14, 2005
genx_7's Avatar
genx_7 is an unknown quantity at this point
did u check the alignment?
Old Oct 14, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
Its probably becuase you have different amounts of grip on each tire. Are you lowered? Do you have negative camber or bad toe? It is possible that the tires ended up being rotated so that the front two tires have grip mostly on the left side of the tread. Causing the car to pull left?
Old Oct 14, 2005
mrb420's Avatar
I am all stock, when it comes to the wheels and body.
I think I might have experienced this problem before on my older car. I think after a about a week, i didn' t notice the problem anymore. Do you think the problem will go away soon, as I continue driving.
Old Oct 14, 2005
MYK1013's Avatar
Thats gotta be your alignment. if it doesnt bother you, wait a while. But i doubt that it will go away like what your hoping.
Old Oct 14, 2005
es2k2's Avatar
Proud to be a civic owner
where did you rotate the tires at? or did you do it yourself???
last time after i did it at honda dealer, my steering wheel was vibrating like crazy and i told them about it 2 hours later, they didn't bother look at the problem and just "unrotate" it.. everything was back to normal then though..
so don't do it at honda if you don't have to!
Old Oct 15, 2005
PunkingCivic's Avatar
I need TP for my bunghole
First check the air pressure in the tires.
IN the rear it wouldn't have been such a burden.
If the problem persist then go have a have a an alignment check done at sears or a local shop.
Old Oct 15, 2005
streetglower's Avatar
Now if this happened after you rotated them, you may have a bad tire. It happened with my car. Had them rotated and it started pulling to the right. I thought the shop had done something to mess with the alignnment, but when I went to get the alignment checked, it was fine, so the tech asked and he suggested checking for a bad tire. Well since it was pulling to the right, he switched the front 2 tires from left to right and the pulling went to the left, so he determined I had a bad tire. I would try that yourself.
If yours is pulling hard to the left, switch the front 2 tires from side to side and see if the problem goes to the other side. If it stays the same, your alignment is probably the cause. If the pulling switches sides, it is probably a bad tire.
Old Oct 15, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
PLEASE READ THIS
I feel it is relevant in a sense if you have done everything else... sans alignment and tire check then follow this
EDIT: the guy is referecing his bike in this but it is all relevant to car passenger tires....and please if you have less than 3/32nd's replace the tires...I don't want you to kill yourself or someone else... (general appeal)
Old Oct 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
^^^ is 100% correct. LOTS of MISSINFORMATION on most all the other replies! If you dont have factual information then please dont clutter post
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Poopies
Apr 20, 2017 11:36 PM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
