new rims (for me atleast!)
Old Oct 10, 2005
954rr coupe's Avatar
954rr coupe is an unknown quantity at this point
a friend of mine had a set of poished aluminum 18"s laying around that he wasnt using so i threw them on my ride. i dont have the specs but will get them tonite and post pics. there seems to be like a whinding noise when driving and the car seems to sway to the right (alignment seemed perfect with stock wheels)... the rims were sitting for about 2 yrs so im sure the balance my need adjusting, tire pressure is good, need to replace bolts (using stock one's now), accelaration seems slower, rotation is in correct direction and my friend mentioned something about a spacer. any ideas what might be causing the whinding noise or swaying to the right?
Old Oct 10, 2005
jameslinkinpark's Avatar
jameslinkinpark will become famous soon enoughjameslinkinpark will become famous soon enough
I'm no expert, but either the swaying is just because no road is completely flat and always causes the car to go slightly right...or you just need to realign now that you have new rims. The acceleration is obviously going to be slower because, assuming you had less than 18" wheels before, they're heavier and require more time to rotate....not sure, but the noise is probably cause of the heavier wheel creating a different type of ride than you're used to.
Old Oct 10, 2005
acidbaby's Avatar
The Beez Kneez
new old 18's=need alignment and balance.... maybe camber kit
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
