ARP Wheel Studs?
ARP Wheel Studs?
Alright. I need to buy some new wheels studs, for the front. I managed to strip one, because my little brother cross-threaded the lug.
When I took it off, it stripped the threads off. So now, I've got 3 lugs on one of the wheels. Also noticed that a few are a little stretched out. So, I'll go ahead and replace them all up front.
I can get the stock Honda lugs for $3.19/ea. That's not too bad. It's $25/8 + s/h. That'll do the whole front.
I know that they're 12x1.5 for the pitch on them. How long are they? I'd like to get a set of ARP studs if I'm going to go ahead and replace them. Might as well get something a little more durable. So, does anybody know what the length is of the lugs are? I found someplace that sells ARP studs for 88-2000 Civics. Would those work? I really need to get lugs ASAP.
When I took it off, it stripped the threads off. So now, I've got 3 lugs on one of the wheels. Also noticed that a few are a little stretched out. So, I'll go ahead and replace them all up front.I can get the stock Honda lugs for $3.19/ea. That's not too bad. It's $25/8 + s/h. That'll do the whole front.
i picked up some for a stipped lug on my rear discs from a 2k3 si. they are the same pitch and everything as the fronts on our civics and only were .99 each at autozone. just tell them what year the car its from and theyll hand it to you. the lug has worked fine so far and was pretty easy to tap in.
The rotors are the same as the 99-00 Si. So if they fit that, then they should be long enough to use. You can always Xreference the old model civic part with the 7th gen part on Majestic Honda. Or call and ask the stealer if they're the same. I have a feeling they are. Word has it you can also use previous gen TL studs (98-2003?) They're longer but I believe they fit. People use those as a cheap extended stud where race rules require them.
nirvanaguy
25
Oct 26, 2017 07:26 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
