Brake caliper
Brake caliper
anybody knows if there's any brake caliper on the market which would replace the oem one without modifications? (i ain't talkin' about big brake kit like brembo & rotora)
thanks guys
thanks guys
thanks guys
thanks guys
Cardone
Beck/Arnley
Raybestos
All these companies make direct oem replacements for a lot less money. Which side do you need replaced?
Below are the part descriptions.
Raybestos RWC50082 (Front right assembly)
Raybestos RWC50083 (Front left assembly)
Cardone 191832 (Front right assembly)
Cardone 191833 (Front left assembly)
Beck/Arnley 0771222S (Front right assembly)
Beck/Arnley 0771221S (Front left assembly)
Also, since you only need the caliper and not the brake pads or caliper mounting, you would need unloaded calipers.
thanks Storm
I wanted to use the rotora front rotors & pads with a new shiny set of calipers
I thought of maybe replacing all of them (2 fronts & 2 rears), the civic is the coupe 2002 UKDM (equivalent to the 2002 EX model in the US)
I'll have a look on their websites
Thanks again!
Thanks again!
forgot to ask
does anyone know if nissin makes brake calipers front & back for the ex 2002?
had a look on the forum & net but can't find any info
thanks again
thanks again
What I wanna know, if anyone could please answer, is if theres a two piston caliper (if possible) replacement for si rear disc brakes, or just a stronger caliper available. response is very much appreciated.
forgot to ask
thanks again
thanks again
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
