17-19 switch
Old Aug 15, 2005
sittinon17s's Avatar
sittinon17s is an unknown quantity at this point
17-19 switch
i have 17" rims with 205/40/17 tires, but they look kind of small and i dont really want bigger tires. im finding some pretty cheap 19's on ebay, so i was wondering if i had the same pro as i do on the 17s, would there be any problem with the tires rubbing the wheel well? thats really the only thing im concerned about
thinking about motegi ff7's or riax secas
Old Aug 15, 2005
Robb989's Avatar
Robb989 is an unknown quantity at this point
I have 18's and I am thinking of going to 17"s because they feel to big and heavy, I would never go w/ 19"s, to big in my opinion.
Old Aug 15, 2005
FALKEN's Avatar
Civicforums Junkie
ive gone from 17s to 19s with no problems/issues
in looking at your ride, id say that you need to drop it first and then look at how it looks/sits...then decide on whether you want to upgrade to larger wheels
i would also suggest going to a 215/40-17 tire if you stick with the 17s
Old Aug 16, 2005
sweeteli99's Avatar
sweeteli99 will become famous soon enoughsweeteli99 will become famous soon enough
Yep, you should drop it.
i went from 15s to 19s. no problems .
Old Aug 16, 2005
djmota's Avatar
You are sporting the SUV look. < my buddy used to tease me with that when I was stock hieght on 17's
take it out of the clouds and drop it. bye bye wheel gap.
Old Aug 16, 2005
i cant drop it because the drivers side rear lower strut bolt wont come out, its fused with the bushing or vice versa. anyway, its a condition i have heard to be common with civics and integras. so wheel gap cant be really be dealt with by dropping, and larger wheels seem the only option
Old Aug 16, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Getting larger wheels won't fill out the wheelwell the way you think it will. If anything it'll exaggerate the gap even more, and your car will look lifted. Actually it WILL sit higher, because the smallest tolerable tire size for 19s (that won't totally throw off your speedo and odo) is 215-35-19, still larger than stock.
Old Aug 16, 2005
well yeah, i know you're right, i just dont want to admit it. hopefully the oem body kit will bring it down to earth a little
Old Aug 16, 2005
boombazokajoe91's Avatar
I survived that B*tch Katrina !!!
boombazokajoe91 is an unknown quantity at this point
yea my car looks like im going mud riding right now .. i just put 18's .. and looks like a put a dam 3 " lift on it ... im dropping it on some neuspeed sports next week
Old Aug 17, 2005
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
Get the bolt drilled out, then drop it. IMO it will look better no matter what wheel size you are running.
Old Aug 17, 2005
peimp's Avatar
peimp is an unknown quantity at this point
i just went from 17s to 19s, it wont fill the gap as much as you would like it to. I did the prokit with mine and it the wheels fit perfectly in the wheelwells.
Old Aug 18, 2005
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
does 19'' rub??
robjcivic
Mar 12, 2017 12:10 PM
MamaBear2015
49
Sep 29, 2015 01:12 PM
Klame9420
Sep 7, 2015 10:03 PM
junkyardguy
Sep 2, 2015 06:07 PM
