upgrading 93 civic wheels
Old Aug 3, 2005
jskull21's Avatar
jskull21 is an unknown quantity at this point
can i upgrade my 93 civic lx with 15 inch rims...i wanna take the original 13s off and put on 15s on my civic from a 2002 civic..../.
thanks guys...
Old Aug 3, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
ya u can do it
Old Aug 3, 2005
jttegx's Avatar
OMNES AD UNUM
yes. just make sure you have the correct tire size and whatnot.
use the tire calculator to see how much of your speedometer would be affected.
and IMO, thats a downgrade. the 13's would be lighter as the 15" steelies are heavier
Old Aug 3, 2005
Jrfish007's Avatar
He might get less tire spin though.
You don't have to worry about the calculator, if....
The outter diameter of the tire on the 13 inch is the same as the 15 inch. If you need help in figuring this out, just let me know!
Old Aug 3, 2005
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
did he just ask us if he can put new rims on his car?
i dont get it
Old Aug 3, 2005
jskull21's Avatar
I took the 15's off my 02civic and wanted to put them on my 93civic. The tires on the 15's are brand new and I was just avoiding a new tire purchase for my 93 by swapping the wheels. I was just wondering if the offset was the same?
Old Aug 3, 2005
offset on all civics are the same.
Old Aug 3, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
would he need hub centering rings?
Old Aug 4, 2005
Jrfish007's Avatar
Shouldn't I think all civic's have the smaller knuckle. If you do need the rings, you'll know, you'll have a major viberation when you stop.
Old Aug 21, 2005
zen_master's Avatar
hahaha, i think i asked about this too...
but not to much of an answer................
btw........u got 93 vic too? heheheheh
Old Aug 21, 2005
tuner04civic's Avatar
spell check pwns you
im doin that to my moms 94 as soon as i put 17's on mine
Old Aug 22, 2005
jttegx's Avatar
OMNES AD UNUM
so you want to take the 15" wheels off your 2003 civic ex (assuming you have one from ur sig) and want to throw them on your 1993 civic lx sedan, correct? if so, yes they will fit cause its same bolt pattern 4x100, the only thing you need to worry about is the speedometer..cause when you change tire sizes, the speedo wouldnt be as accurate. check out the tire calculator under "quick links".
it'll fit no matter what, question should be whether if your ok to alter your speedo...
but if your gonna throw the 13's on the 2003 civic... you may have a problem possiblity... not sure
Old Aug 22, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
They've been the same since 88, maybe earlier, but definitely 88....
56.1mm hubs, same offset (it depends on the OE rim width), what fits one fits them all.
The tires will be too big, you probably need to go down to a 50 or 55 profile.
bsmiley
Apr 27, 2015 01:27 PM
nickeynick
Apr 27, 2015 01:23 PM
veloce
Nov 10, 2001 01:19 PM
Lightman
15
Nov 8, 2001 05:06 PM
GabberHead
Nov 1, 2001 02:28 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
