not the rim type but need help
Old Aug 2, 2005
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
hey ever since i put on the 17" when i drive its like all off n stuff
y is that?
does ne1 have the same problems? i guess not./
and when it hit a lil bump, bumpy road, the railroad. it seems like the wheel just follow the road n not my steer.
i didnt drop it... tires r in good shape.. rims r .....yea good
i just scratch it on magnolia try to bust a u turn into starbucks...sonofa...
so yea...
how can i get the feeling like i was on my old 15" wheels?
do i have to realign and everything?
Old Aug 2, 2005
y.0. KiLLa's Avatar
Powered by Honda
Old Aug 2, 2005
FALKEN's Avatar
Civicforums Junkie
my head hurts after reading that
Old Aug 2, 2005
2slow2run's Avatar
wut time is it now
how can i put it so itll b ez to understand...its like um...the wheel follow the road.
that kinda feeling..
like when the bump is like kinda on the left
then the wheel will go left instead of keep'n str8ght
yea thats wut im talkn bout
my steer'n isnt str8ght on like it was when i was on the 15"
n it doenst kill as much brake as the 17"
Old Aug 2, 2005
noVICe's Avatar
noVICe is an unknown quantity at this point
why do you
type like this? one line
or so would be
fine. punctuation and
grammar helps alot on this
forum, so please
stop typing like this.
thanx.
Old Aug 2, 2005
noVICe's Avatar
oh... and alignment should be done after any drop... as well as a camber kit. dont expect to have the same comfort with an upgraded suspension.
Old Aug 3, 2005
wonderz's Avatar
wonderz is on a distinguished road
i think he's only talking about putting new 17" wheels...
i didn't see anything about suspension or drops... well, not like that i know of.
Old Aug 3, 2005
noVICe's Avatar
^^^ oh yea... my bad. didnt see that.
Old Aug 3, 2005
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
What tires do you have. My guess would be that when you got 17"s you also got wider stickier tires. Now you have more contact with the road & the tires are doing what they are designed for....sticking to the road.
Old Aug 3, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
did u get the car aligned after u put the tires on? i think i sorta get u but at the same time dont.
Old Aug 3, 2005
jttegx's Avatar
OMNES AD UNUM
are all tire sizes same and match?
were the wheels mounted and balanced properly? (who installed the tires on the 17's?)
what size tires are they?
Old Aug 3, 2005
2slow2run's Avatar
wut time is it now
is kumho ecsta something 205-40r-17
is sticking to the road no i just got it from a friend n put it on.
i mean everything is find but like if the road is bump'n it stick'n to the road.
like my steerin wheels moving left and right. ne1 noe wut im talkn bout?
Old Aug 3, 2005
wonderz's Avatar
make sure the wheels are balanced if your steering wheel is moving left and right.
Old Aug 3, 2005
2slow2run's Avatar
wut time is it now
like i notices all teh wheels,
the diver side has 5 of those weights.
the back of the driver side has 4
the back of the passenger has 3
and the passenger front has 2 (theres a shading like 1 of it fell off or something)
there like 1/4 oz..is it suppost to b like that? i thought all of them should have the same amount usually my old donuts have 1 fat clip on it.
it only turn like left n right when im on a bumpy road..other then that str8ght road its fine
Old Aug 3, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
its the tires. when i had kumho 712 they followed the grooves of the road a lot. must be a kumho thing.
Old Aug 3, 2005
jttegx's Avatar
OMNES AD UNUM
hmm not sure what your talking about when you said "weights". im guessing the clips that you use when mounting new tires on? but otherwise, only 1 is neccesarly used.
205/40/17 is a very low profile tire, you have to expect to "feel" whats on the road mostly when your driving on rough roads.
have someone take a look at it. drive your car slowly and have someone inspect your tires to see if they are not wobbling.
Old Aug 3, 2005
2slow2run's Avatar
wut time is it now
well i guess ill have it check out
well thankx for the support
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
anubis62
Sep 27, 2015 12:56 AM
