2 screws on the rotor...
Old May 31, 2005
civic12's Avatar
civic12 is an unknown quantity at this point
i recently had to drill the 2 screws out of the rotor to get it off cause the screws were stuck due to rust and what not......well anyway i was told that i didnt need them on there and that when i put me wheel on that my lug nuts would hold it all on...is this true.....and what size screws fit in those holes....i really need to knwo this....thanks..
Old May 31, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You don't need them at all, I don't even bother with them anymore. I believe they're 6mm screws if you so desire.
Old May 31, 2005
civic12's Avatar
well...i recently had 4 wheel alighment done and i have camber kits on both frotn and back but i stil have a shaky front end/steering wheel...its comes and goes...but on the fourlane its there constantly...i am lowered 2 inch with 215/35/18.....do you think its just the tires and rims or do you think i need to get them balanced or anything??
Old May 31, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
u dont need em..
Old May 31, 2005
tacheon's Avatar
tacheon is on a distinguished road
Ok. Those bolts should have been removed with an impact screwdriver. It gets them out almost everytime and they can be reused. Now, contrary to what you might have heard, these bolts serve a purpose. They align the brake disc to the hub assembly to reduce radial runout. Brake discs new or used have ring-groves on the surface due to machining and brake pad contact. When you mount the disc without the screws, there is a lot of play in the radial directions (up/down/left/right). That puts the ring-groves off centre, thus causing excess radial runout. This usually manifests itself as vibration under braking. Putting the bolts on centres and aligns the disc to the hub, thus preventing this from happening. If I were you, I'd replace them. They're cheap anyhow.
ricer_em2
May 11, 2016 08:09 PM
redcloud
Sep 7, 2015 01:45 PM
Klame9420
Aug 13, 2015 06:00 PM
ballmich
Jul 9, 2015 11:59 AM
