tire balancing question
Old May 1, 2005
streetglower's Avatar
My mom had new tires put on yesterday at discount tire and everything is fine but I was wondering I was changing her oil yesterday and noticed that on the right front tire there are 2 wheel weights on the inside of the rim, they arent next to each other but they are accross from each other. One is 1.00 weight and the one accorss from it is a 0.75 weight. there is only one on the outside rim, but is this ok? none of the other tires are that way, all the other tires have one weight on each side. The rim isnt bent or anything. I have tooken a class in school on tires and balancing but cant really remember the tire balancing stuff. I have been told as long as the tire balances it is ok, but also you dont want weights all over the tire. But 2 is ok. Just wondering if this is normal?
Old May 1, 2005
italy273's Avatar
italy273 is an unknown quantity at this point
yea its ok.. Some places use machine that balances the tire using the lugs instead of the centric ring, like the Hunter GSP9700. the machine tells specifically where on the tire it's not balanced. This cuts down on tire vibration. Some rims require more weights than others.
Old May 1, 2005
cool, thanks just wanted to be sure, her other tires had only one weight on each side so I wasnt sure.
Old May 2, 2005
dxray's Avatar
dxray is an unknown quantity at this point
I have a couple like that and had no problems.
Old May 2, 2005
tfnaaf's Avatar
BLDNPSI Mod
typically what it means is they put weights on, spun it again to zero balance it and it called for more weight in a different spot. This is sometimes caused from balance error, and or the tech that did the work fooked up
Old May 3, 2005
myGFgottaCIV's Avatar
myGFgottaCIV is an unknown quantity at this point
... and was too lazy to try again from the beginning
Old May 3, 2005
ncirom2003's Avatar
precisely, they probably just put the first weights a lil off and exposed a new problem, your tires will be fine dont worry,
Old May 3, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
That's half *** work......essentially that tire is counter balanced. I'd make them re-do it. My guys would never get away with that kind of work....
Old May 3, 2005
_Viper_'s Avatar
im getting Honda to install wheel wheights that are stuck inside the rim
Old May 3, 2005
ncirom2003's Avatar
just some helpful info.
when mounting a tire you mount the yellow dot next to the valve stem, then try to match the red spot with the low-point of the rim. check if the yellow dot is near the valve stem and if it isnt than that would most likely be the reason why they added 1 extra weight, and its not half-assed it doesnt make a difference.
Old May 3, 2005
Broken Road......
It is half assed, lazy work. You have 1.00 and .75, 180 degrees across from one another.....when in relaity you may only need .25 on that side of the rim. Lining up the yellow dot with the valve stem has nothing to do with 1 extra weight, it has to do with people not knowing WTF they are doing. It is the kind of sh*t work I see from Sears, Wal-Mart, Americas Tire, Costco, and the other discount chains, and in my shop it is not acceptable, plain & simple. That type of work comes from the same shops that do crap alignments for some of you, as well as 'forget' to tighten wheels, and leave oil drain plugs loose.....
Old May 3, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
umm.. I've actually come across tires where this was the situation. I was the tire installer, btw. I thought I messed up on the weights, or it was a balancer error. So I took the weights off, and re-did everything, and the situation was the same. I had 2 weights across from each other.
Sometimes this is the situation. It has nothing to do with lazy a$$ people. I noticed this happens more on trucks and vans rather than cars.
Old May 3, 2005
Broken Road......
I have been doing this for the better part of 16 years, and unless you have a balancer with a calibration issue, it should not happen.
Old May 3, 2005
but Is it something to worry about? It is on my moms car, and she wants to know if it will be an issue down the road? Will she have tire wearing issues different from the other tires? She wants to know if the tire will wear out sooner or have tread issues?
Old May 3, 2005
tfnaaf's Avatar
BLDNPSI Mod
^^^^^^ is 100% correct . i wouldnt be WORRIED per say about it. But in the real world it does happen. Hell, im sorta surprised when i see a tire jockey actually zero balance a tire in the first place
Old May 3, 2005
gh0st's Avatar
TAQUITOS!!!!
isn't it possible that there's more mass on one side of the tire?...
Old May 3, 2005
ncirom2003's Avatar
yes^
i dont agree that it should never happen like this because if the top of the tire is perfect on both sides and has a 1g weight on inside and bottom of tire has .75g weight on outside it could be because the two sidewalls on the bottom are diff, now im not starting an argument, this is just how i see it and many people ive talked to said that it is possible and that theyve run into the problem that a machine will say put xx weights on this side then spin it again and it will say put xx weights here.
it is possible my fathers machine needs recalibration but ive done alot of tires (sometimes 15 a day) and ive run into this problem before. it can be considered half assed but it really doesnt matter. its just one of those situations where its a judgement call. if it kept telling me to put more weights without a question id restart it or if it said to put more than 1.5g on a side id try it again. for extremes like that id say its half-assed
Old May 3, 2005
maybe you should take it to a real repair shop that specializes in balance/alignment and not some idiot place like sam's club or discount (crappy) tire. My balance was seriously messed up and the stupid place was not able to do it right at all. Took it to somewhere better and its perfect.
Old May 3, 2005
Broken Road......
We zero out all of our tires, and in extreme instances, can do a 'target' method, and go from increments of .25 ounce to .01 ounces. That is for your really sensitive stuff, but otherwise, always zeroed. After the weights are put on, we spin it again to check it. Just the way I expect it done, nothing else flies as long as I ruin the show.
Old May 3, 2005
tfnaaf's Avatar
BLDNPSI Mod
i personally zero out every tire i balance, but then again i balance maybe 4 tires a month anymore
Old May 3, 2005
ncirom2003's Avatar
ive never let a tire go that wasnt zeroed out, i think its stupid if someone does and id flip out wanting my money back if i saw someone do it, or if they were doin it at my shop id hit them with a tire iron
Old May 4, 2005
i smashed my finger putting a big as wheel on the balancer.. caught between the wheel and shaft.. this was yesterday.. i think i gotta bring it to the hospital.. my entire first digit of my fiber if full of blood
Old May 4, 2005
ncirom2003's Avatar
^ damn sounds painful, one time i was mounting a tire and the bead wasnt sitting on the lip yet so i was pushing it down to loosen it and it finally popped up and caught the tip of my fingers between the bead and the rim, with so much psi in the tire i couldnt imagine how much pressure was on my finger tip but it hurt for a week
Old May 6, 2005
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
I balance every tire to at least 0.15 ounces (usually better than zero on round off setting). When on the round off setting, a tire could be at 0.24 ounces but it will round off to zero. It's nothing you'd feel, i mean you could have a rock in your tread that is 0.25 ounces. I work at Costco and no we are not a bunch of hackers!!... at least not at the one i work at. Unless the rim or tire is sereously messed up, we never have 2 weights per side and never have more than 2 ounces per side, or a total of 3 ounces both sides added together. Anything more and we start to match mount, or used a different tire.
Old May 6, 2005
ncirom2003's Avatar
if a rim is messed up to the point that extreme weights have to be added you might want to check the tire for lateral runout and then dismount and check the rim for laterla runout, they could be bent
Supramk3
Jun 11, 2015 11:13 AM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
viper775
Dec 9, 2001 10:52 PM
technosilver
Nov 14, 2001 10:58 AM
