help ASAP
Old Apr 29, 2005
rokenrolcivic's Avatar
rokenrolcivic has a spectacular aura aboutrokenrolcivic has a spectacular aura about
help ASAP
Ok i bought some 04si alloys and im using my tuner lugs from my old rims to put them on, Is this ok? the lugs seem to stick out pretty far? I dont wanna use my oem lugs cause i dont want these wheels ripped off? I just wanna know if its ok and why they stick out further than the actual wheel???
Old Apr 29, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
I think the 04Si wheels are a ball seat lug nut, like your OEM nuts. Tuner lugs are probably acorn, so you shouldn't use them anyway.
Old Apr 29, 2005
i just put em all on, the seem to fit fine, and they dont stick out much further than oems actually. Think its ok??? ANYONE??
Old Apr 29, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
well, I have never seen the Si alloys up close but you should judge for yourself. If the place where the lug nut sits is rounded, use the tuner ones, otherwise, OE.
Old Apr 29, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
yeah, they're gonna fit, but they're not going to fit the wheel seat, which you can't see with the nut on. You're putting a cone in a spherical seat. so not much is actually contacting the wheel. Use OE lugnuts with OE wheels. Honda sells OE lock sets. Mcgard also makes ball seat locks.
Old Apr 30, 2005
ncirom2003's Avatar
like its been said twice, it wont work cus they arent meant for it
Old Apr 30, 2005
thanks guys, ya I ended up putting the OEM lugnuts on cause I didn't wanna take any chances, with my luck my wheels will get stolen before I get the new lock nuts.
Old Apr 30, 2005
l3lackstatic's Avatar
l3lackstatic is an unknown quantity at this point
i put my tuner lugs on my stock wheels a while back cuz i lost my oem lugs and boy was i sorry, i drove down the street and it sounded like my wheels were gonna fall off, i ended up stripping one of the bolts and having to get it replaced, just dont do it, find your stock lugs
Old Apr 30, 2005
jttegx's Avatar
OMNES AD UNUM
use the OEMs and look for wheel locks asap to be secure.
Old May 3, 2005
thanks again guys
