Is 50 PSI too much for 215/35 18in. tires?
Old Apr 2, 2005
civic02ex's Avatar
got banned
civic02ex is an unknown quantity at this point
Hey guys,
A thought dawned on me today that instead of airing my Pirelli 215/35 18in. tires to 35 PSI, which I thought was close to factory, I should look on the side wall of the tire and find the correct PSI.
I found that the recommended tire pressure for these tires is 50 PSI !!!
But it seems too much pressure for such a little tire when my factory tires are only 30 PSI & alot bigger than the tires I have now. So I just aired the tires to 40 PSI, noticed the car picked up quicker, but the ride is more stiff.
So what do you recommend........follow the 50 PSI or stick with 35 PSI? Thanks!
Old Apr 2, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
I think tires are not reccommended for above 40 psi, at least not mines.
Old Apr 2, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
it probably says MAX recommended pressure. No tire has a recommended PSI, that depends on the car. But they tell you a level that you shouldn't exceed.
Old Apr 2, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
50??? whoa!
Old Apr 3, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
My tires hold 50 PSI max too. I have toyo proxes 4's, and I would never set my tires at 50 or even close to that. Right now, my tire pressure is set at 35 psi. I just put on my tires 2 days ago, so I'm gonna experiment anywhere between 30-35 psi.
I would recommend setting it at around 30-35 psi.
Old Apr 3, 2005
olytrojan's Avatar
Senior Member
olytrojan is an unknown quantity at this point
the pressure on the sidewall is the max pres. for the tire. on that size tire you should run between 35-40 psi
Old Apr 3, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i generally run 30-35 also, but i have 16" rims... to high pressure, especially with such low profile tires, you risk damaging the tire itself.
Old Apr 5, 2005
CivicMahem28's Avatar
CivicMahem28 is an unknown quantity at this point
Dont Fill Your Tires With 50 Psi Your Asking For Trouble .........that Lable On The Tire Is Just To Let You Know Of The Max Psi The Tire Can Hold ....you Should Put 35 Psi In Your Tires , While Your Tires Are Cold ( Example.... In The Morning) Why? Because Heat Has A Tendancy To Expand (while Driving) And If You Put 35 Psi While Your Tires Are Cold Then That Air Has A Much Better Chance Of Expanding But Not Exceding The Max Psi So Just Imagine what can Happen If You Are Riding On Tires Filled With 50 Psi .......if You Still Dont Believe Me Do A Little Science Project Stick A Coke Can In You Car , Windows Up, (on A Hot Day) And Watch What Will Happen When Heat Expands In That Coke Can
mjdiaz89
Jun 21, 2016 09:26 PM
SidCivic
Oct 3, 2015 06:00 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
