anyone heard of tire swelling?
Old Mar 28, 2005
kkk's Avatar
kkk
kkk has a little shameless behaviour in the past
heylo all. i tried to search but coudlnt find anything . tht means tht this problem is not so common.
i have dunlop sp9000 215/40/17's .
and on the side walls , i can see swellings. why is this? is this a problem?
its like the tire as lost its shape and swelled for some reason......
Old Mar 28, 2005
scatman's Avatar
Still in the game...
hmm, that happened on a couple pirelli tires that my friend had. im not sure what causes it...
Old Mar 28, 2005
gh0st's Avatar
TAQUITOS!!!!
sounds scary...
Old Mar 28, 2005
tfnaaf's Avatar
BLDNPSI Mod
do you mean there is a bump outward? If so any bumps/bulges outward are unsafe and should be replaced.
Old Mar 28, 2005
olytrojan's Avatar
Senior Member
olytrojan is an unknown quantity at this point
thats called an impact break. what happened was you hit something(like a pot hole or a lip in the road) that broke some of the nylon cords in the sidewall of the tire creating a weak spot in the tire. since there is nothing to hold back the air other that the thin layer of rubber of the sidewall it gets pushed out. if you leave it for too long the rubber will eventually fail in that spot and you will be sol.
Old Mar 29, 2005
kkk's Avatar
kkk
well i dont really remember hitting a pot hole so hard. plus my rims are in good shape nothing wrong with them.
mayb there are many holes where i live so wats the solution? put more air in them? get higher profile tires?
Old Mar 29, 2005
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
solution = get new tire. trust me i had um and the only way is get new tires.
Old Mar 29, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
you can also get them from over inflated tires or carrying to heavy of a load
Old Mar 29, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
Yep, this is the only thing to do.
You can't do anything about this except get new tires. Buldges on tires are more common than you think. It happens on tires with low profile or high profile, so it doesn't really matter if you have low or high profile tires.
Old Mar 30, 2005
jttegx's Avatar
OMNES AD UNUM
highly recommend replacing that tire. mostly when you have a low profile tire.
had one of those on my acura for few months, didnt blow or anything cause it was a fat tire (205/60/16). but try to get the tire replaced asap cause they can blow at anytime causing you a flat and im pretty sure you dont want to damage your rims or spend a day on the side of the road.
15EXCoupe
Jul 30, 2015 12:59 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Q-Bert
Jul 19, 2015 09:09 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
