tires for 18s without rub?...
ordering my 18s soon....im gonna get a wheel/tire package but the tires that come with the package are 225/40/18.....and im lowered 2 inch now.....im just wondering if these tires will rub or anything or should i get 215/40/18??...any help is appreciated...
you should be ok depending on how well your suspension is. I had a problem before I changed my to my tokico struts with eiabach springs.
well.. 215/40/18 and 225/40/18 has only difference of 4mm side wall and radius
id say go for 215/35/18
with 2 inch drop + camber kit, I dont think you can fit 225/40 even if it has right offsets and stuff. unless you wanna roll your fenders
if those are your only choice, go for 215/40/18
i have 225/40/18's on my car with neuspeed sport springs(1.75 front and 1.5 rear drop) and stock struts and they only rub when i go over bumps or dips at 50+. i used to have the 215/35/18's and they rode like rocks because they barely have any side wall. i would say go with either 215/40/18 or 225/35/18. the 225/35 is almost exactly the same diameter as your stock rollers, their just wider by 30mm (a little over an inch)
Originally Posted by scatman
whatever you do, dont run a 35 sidewall, its way to narrow IMO.
alaga
25
Aug 13, 2015 04:42 PM
