Hawk(hps) or Hawkceramic pads?
Old Mar 12, 2005
Black03civic's Avatar
Okay guys, getting ready to change my breaks. I will be getting brembo blanks,and new shoes for the drums in the rear. But i am unsure about the stoping power of the two pads. Are the ceramic pads same as oem in stoping power? I would just be using the car for daily driving. Thanks for your imput.
Old Mar 12, 2005
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
the ceramic ones should be a little better than stock (because stock brakes suck) where the hps is a performance style brake. if its just daily driving either would be fine, but the hps will have a little better stoping power.
Old Mar 12, 2005
dirtySAMURAI's Avatar
I log in from time to time
hps is awesome. i think i wore them out though (8,000 miles...lol)
Old Mar 12, 2005
Hawk's Avatar
You boost, I-VTEC
HP+'s are the **** if you don't mind your car making more noise then most transit busses. I ran on a track for 2 days and only wore like 1/8 of a inch off of them.
Old Mar 14, 2005
thanks for everyones imput, i think i will go with the ceramic hawk pads due to the noise.
Old Mar 14, 2005
wonderz's Avatar
wonderz is on a distinguished road
i had hps pads and i only made noise when the brake was applied lightly like slowly moving out of parking spots and stuff. otherwise its fine.
Old Mar 15, 2005
Mr.Modify's Avatar
i used them before.....they squeak but that's only because you have to heat them up first. Once you got them heated there fine.
Old Mar 15, 2005
Really? if that is so, then i might just go wit the HPS then. Thanks for your imput.
Old Mar 16, 2005
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I have the Hawks with OEM Rotors. Feel normal during day to day driving. Mountain runs however are much nicer. I don't notice that much of a squeek either.
Old Mar 17, 2005
Thank you for the information, i have decided to get the HPS with the brembo blanks.
Old Mar 17, 2005
Phil_Qc's Avatar
Phil_Qc is an unknown quantity at this point
don't forget...
I suggest that you do the burnishing processus (spell ???)
or you will glaze the pads very easily. I skip this step when
I instal my HPS and that's the problem I have. These pads
work way better than the stock ones !
Philippe
Old Mar 17, 2005
sKwiD's Avatar
I Queef > You
Hmm, I didn't do the burnishing process... Whatever that is. Is it when you go fast, brake hard, slowly brake, all that in order to break in the pads? I asked the guy who did my brakes whether you have to do that or not and he said it was unecessary. What does it actually do?
Old Mar 17, 2005
Phil_Qc's Avatar
Ok, the bed in process give you a consistant braking power
and the ability to accept more heat. I did not do that w/ mine
and I glazed the pads. Now they brake like sh\t, I lost all the
modulation (ability to controll). When I press hard on the pedal,
it stop good but at first, when they were new, the power was
way better than that. I'm hard on brakes, next time, I will try
the HP+.
Sorry for spelling, I hope you understand.
Philippe
Old Mar 17, 2005
AzNBonD's Avatar
AzNBonD is an unknown quantity at this point
Yeah it's better to bed in the HPS, as for burnishing, I believe they're burnished at the factory.
I recently installed Hawk HPS and Brembo blacks, awesome combination, i haven't really tested the braking though since I've been going easy. But they work so well, that on snow, the ABS kicks in really early... even on the lightest braking.
I've also been told that replacing the brake fluid with something like Motul will yield a noticeable difference. But i guess getting a less hygroscopic (i dunno the "automotive" term for it) will yield better performance anyways.
Old Mar 17, 2005
SWEET that what i want to hear.
Old Mar 18, 2005
Titleist71's Avatar
I have the HPS and Powerslot's. They are perfect for each other. The paper work that comes with the Powerslot'd say to use Hawk HPS. The Hawp Race pads are nasty but they need to get warm and they hummmm...kinda cool.
SammySC
121
Apr 7, 2017 07:43 PM
speedlever
Sep 24, 2015 07:18 PM
sf3r8z
Sep 23, 2015 03:26 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
DerbyDad03
Jul 27, 2015 11:34 AM
