Rear discs are overrated
Old Feb 28, 2005
nindoo's Avatar
Why is my vagina bleeding?
http://www.canadiandriver.com/testdrives/index.htm
Acura EL 60mph-0 distance in ft (This is a civic EX sedan with rear discs instead of drums)
147
Honda civic EX Coupe 2002 with ABS braking distance 60mph-0
141
What's weird is that the four door lx model with ABS has a longer braking disntace.
Mazda 3's have really good braking distances on msn.
136 ft for the base model and 121 ft for the GT hatch.
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
Who ever told you that 4 wheel Discs or ABS would stop you quicker?
Old Feb 28, 2005
HondaLuver's Avatar
Its a celebration bitches!
humm, yea... abs helps u control in a hard braking situation... and 4 discs help prevent over heating in the the rear drums
u know the one thing to really help ur stoppage is tires... the only thing between the car and the ground... u can stop only as good as ur tires
Old Feb 28, 2005
runner1738's Avatar
true, but most will say abs helps you stop faster in a panic situation so you dont end up sliding as if you didnt have abs and are a non experienced driver
Old Feb 28, 2005
nindoo's Avatar
Do you think tires are the main reason the Mazda 3 has better stopping than the civic coupe? It has slightly bigger front rotors, our front rotors are 10.3 inches and they have 10.9inch front rotors in the base model. We have 7.8 in rear drums and they have 10.4 inch discs. Its probably a combination of tires and brakes, there GT model has even bigger brakes.
Old Feb 28, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
147
141
The SI has longer braking distance than the ex coupe(ABS) from 2002 aswell
coupe is lighter than a sedan ...
but that is very odd ... I would think that rear discs would stop you better ...
zzyzx: if the car had awesome tires, a rear disc setup would stop better than a drum setup, isn't that true?
Old Feb 28, 2005
nindoo's Avatar
aznboysrfr yeah its a little odd. Even though the numbers are from the same website maybe the test drivers are diff.
Old Feb 28, 2005
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
disc size has nothing to do with stopping, only heat dispertion. so if a car has discs the brakes won't fade as easy that is it. hell they used drums on the bombers in WWII to stop them on the little tiny islands. drums are actuly very efficent and stopping but very crappy at getting rid of heat.
Old Feb 28, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
drivetofast had rear discs on his car and his car stopped much, much, much better than mine ...
I don't think it was psychological though ....
Old Feb 28, 2005
nindoo's Avatar
So if they dissipipate heat better they serve to last longer during a race, but might have asverse affects on your braking distance.
Old Feb 28, 2005
nindoo's Avatar
Do you guys have diff tires?
Did he change his front brake pads?
Are your rotors glazed?
Maybe he's messed around with the pedal feel where he doesn't have to push it as much to get the brakes to force.
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
Honda Is notorious for under tireing their cars (S2000 Aside..) So, what tires does the stock Mazda 3 come with (Size, make and Model) and compair that to what the civic comes stock with (Size make and Model)
Not nessisairly, see given the same cars, one with 4 wheel disk and one with Disk + Drum.. both cars should stop in the same # of feet. what the disk will give you is the ability to push the brakes Hard Longer... (Less brake fade) But as far as one panic stop... there should be little to no difference between the two.
what tires was he running Compared to yours?
Old Feb 28, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
he had parada spec 2's 215/40/17 and I had 225/50/16 goodyear eagle f1 gsd3's
rims.. his were heavy 7 spoke giovanna rims and mine were ssr comps ...
Old Feb 28, 2005
nindoo's Avatar
Mazda 3
195/65R15 all-season tires (GX, GS)
205/55R16 all-season tires (Sport package, GT)
Toyo AO5 for the base model
Goodyear RS-A and for the GT
Honda Civic Ex Coupe (early 7th gens)
185/65HR15 Firestone FR690
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
I dont know what to tell you. Other then I know for a fact Disc brakes on the rear of our civics will not stop you quicker. what they will do is give you more consistant stopping over multiple stops, but they will not stop you qicker. (I can get in to the Hows & whys if you'd like)
BTW, how were you compairing stopping distances?
Nindoo:
Whats on the civic? (mines never been stock...)
Old Feb 28, 2005
nindoo's Avatar
Nindoo:
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
Mazda 3
Theres your stopping distance difference right there...
The honda not only has a harder compound tire, but its also narower....
The Fireston FR690 is a "Standard all season tire" with a tread wear of 440...(Rock)
The Toyo AO5 ... I cant seem to find any info on..
The Goodyear RS-A is classed as a "High Performance All-Season" and has a tread wear of 260.... Much stikyier then the Hondas tires.
So, I'd suspect most of the stoping distance difference between the two is simply tire choice.
Old Feb 28, 2005
nindoo's Avatar
Who knows maybe our stopping is even better with the same tires.
Would these be a very good upgrade over stock
Falken Ziex ZE-512
195/60R15
Old Feb 28, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
zzyzx: it seemed as though the with moderate pressure on my brakes, the car would slowly and gradually come to a stop ...
but on my friend's car, it seemed to push me forward as it stopped
Old Feb 28, 2005
nindoo's Avatar
Probably the pedal set-up.
Old Feb 28, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
pedal setup? ... I dunno, who knows. my brakes seem to work very well when my engine was cold, but after a little bit of normal driving, the brakes turned to ****.
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
Pad Compounds will alter how much pedal preasure is needed to reach a tires "Saturation" point. so if your friend is using a "stickier" pad (One with a Higher friction level) he will use less pedal to reach that "saturation" point.
Personally, I think you just need to be a little more Enthusiastic with your brakes... as in You need to learn the limits of your brakes. you'd be supprised how much harder you can use your brakes once you lean when/where your tires will begin to lock. (Threashold braking) The important thing is that your application of the brakes is smooth. as in dont pounce on the brakes, But rather try to have a smooth progression on to the brakes (To allow weight to transfer forward). once weight is on the front end you can really apply the brakes.
Old Feb 28, 2005
nindoo's Avatar
Can I still push my brakes hard or will ABS not let me?
Old Feb 28, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I suppose. I don't like to be too harsh on my brakes though (but at the same time, I didn't treat his any differently).
I MAY be mistaken, but I believe he had hawk pads on the rears ... I know he had honda pads on the front with stock rotors on both ... I also had stock pads and stock rotors ...
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
the only thing ABS will do is try and stop a wheel from locking if you hit sand or something while you are heavy on the brakes. otherwise, if/when ABS does kick in, just keep the preasure on, and let it do its job.
BTW, if you get really good at threashold braking, you will beable to stop faster in stragiht line DRy braking without ABS...
Old Feb 28, 2005
nindoo's Avatar
So I'll get shorter braking distance if I practice that smooth weight transfer stuff. I shouldn't depend on the ABS and just stomp on the brakes and lets the electronics take care of it.
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
Personally ABS annoys me in all but Low traction and Emergency situations. I disable (pull one of the fuses) it when I race. What you should probably aim for is being able to use the brakes to the point Just before ABS kicks in. If it does kick in just ease off a little.
Old Feb 28, 2005
nindoo's Avatar
Cool So I can pratice nonetheless. Instead of skidding I'll feel some clicking to let me know I'm screwing up.
Old Feb 28, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
i heard someone tell me that rear disks help keep the front of the car from "diving" as much... is that correct?
Old Feb 28, 2005
Zzyzx's Avatar
Autocross Junky
Weight is still going to transfer to the front.... so I'd have to say no, rear discs will not reduce Diving.
Changing shocks Can influence that a bit... but only by slowing it down. the same amount of weight is still going to get transfered.
