225/40/18 rub?
Old Feb 20, 2005
horty222's Avatar
horty222 is an unknown quantity at this point
225/40/18 rub?
I want to get some axis spiders 225/40/18 setup. Does anyone have that size setup and will it rub? I want to get them from nextwheels.com and they give you free springs. I will be droping my civic. please advice on any rubbing. I dont want to go with 215/35/18 because i had that setip twice and both times I bent multiple rims.
thanks
Old Feb 20, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
depends on how low you'll be dropping your civic. you'll be safe with a 215/40/18 tire and an 1.75 drop all around
Old Feb 20, 2005
chrisleecool's Avatar
I'm pretty sure it'll rub with over 1'' drop
Old Feb 20, 2005
BaLisTek's Avatar
i like shiny cars
BaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant future
I got 215/40/18 and i've only knicked my rims twice in the same spot. I had my rims for over a year with shitty Louisiana roads. If u still want the 225 silvrbreeze has that setup and he's dropped. Look in the louisiana forum and ask him if he is rubbing.
Peace
Old Feb 21, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
i think offset plays a major role in this, as well as rim width.
i beleive your rims need to have like 45+ mm offest to properly fit a 8 inch wide wheel with 215. to ride a 225 i think you need like 48mm offest? PM rijowsock.
Old Feb 21, 2005
scatman's Avatar
Still in the game...
thanks
dude, you'll be fine.....and its wheelsnext , not next wheels.
Old Feb 21, 2005
born2xLr8's Avatar
I have 18x7.5 rims with a 42mm offset and 225/40/18 tires. It will occasionally rub when I drive over dips at 70+mph or turning the wheel all the way to make a u-turn.
I'm also lowered 1.75" in the front and 1.50" in the rear.
Old Feb 21, 2005
nickm748's Avatar
Kinda off topic, will I rub with 215/35/18 40mm offset, with a 2inch drop?
Old Feb 21, 2005
Michalo187's Avatar
Abortion Survivor
thanks
I have the same size and when i turn right it rubs sometimes but like steering wheel completely turned. When people get in the back hits the fenders everybump but other than that they are always fine.
Old Feb 21, 2005
silvrbreez02's Avatar
silvrbreez02 can only hope to improve
i have 225/40-18 with an H&R sport springs drop (about 1.5" all around).....no rubbing.....ever
Old Feb 27, 2005
horty222's Avatar
thanks for your help
Old Feb 27, 2005
NightRider02's Avatar
sleekest 7th gen on the right coast
NightRider02 is an unknown quantity at this point
thats the exact tire size i have right now, and my car is lowered about 2.5 inches, and i dont get any rubbing whatsoever
Old Feb 27, 2005
2k1civic.com O. G.
i think it also depends on the width of your rims. I have 18 x 8 rim. I have been told that an 8 inch wide rim will require a +45 mm offset to be perfect.
Rim expert rijowysock has told me i have to go with a 215/35/18 becuase of my width. I have also been told this by two people at tirerack.com ( roger@tirerack.com and Riley@tirerack.com )
What is the offest of your rims? how can you guys run 225/40?
Old Feb 27, 2005
not sure offset, but i think my width is only 7.5" (not sure on that either thought)...but i definitely don't rub
of course i'm only lowered like 1.3" (as claimed by H&R), bout 2 fingers gap up front and 1 finger gap in back
i would trust what rijowysock says, he has gone through a lot of wheels, but in my recent experience....no more than a 1.5" drop and that size will work with no problems
UltraHDGames
Jun 8, 2016 05:16 PM
cukaracha
Aug 29, 2015 05:27 PM
Pudnite
May 9, 2015 07:51 PM
soljahboy17
Apr 1, 2002 03:24 PM
