Quick Tire mounting question
Old Jan 26, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I have a quick question to settle a dispute between my dad and me, Can the rim center caps be on the rim or do they have to off the rim to mount a tire?
Thanks
Old Jan 26, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
On the modern rim clamp machines, the center cap can stay on, the machine clamps the lip of the wheel. On an old center post (like a bulletproof Coats) the post on the machine goes thru the center of the wheel. But to balance them, the center caps have to come off.
Old Jan 26, 2005
danscreations's Avatar
Tuckin' 19's
danscreations is an unknown quantity at this point
On a normal size tire thats true! You can push the tire in the rims drop center and hold it so you can get the bead on the rim. However! With a low profile tires you will 99% of the time use a special tool that you need the center cap out for that forces the tire into the drop center as it almost impossible to do by hand.
Old Jan 26, 2005
hotrodcivic2004's Avatar
my civic has no boost
the center cap on stock rims pop out and pop right in like nothin.
Old Jan 27, 2005
Broken Road......
Wanna bet??!! We can mount 35 series tires, in almost any rim diameter, without any special tool. It is a matter of knowing what you are doing.....
Old Jan 27, 2005
scansel912's Avatar
Well damn, I just put a center cap in my new rota slipstream wheel 15", and two of the 8 prongs broke. Im worried that when i take it out, that more clips will break and means I have to get a new center cap. Any ideas on how to take it out without the plastic breaking? Thanks
Old Jan 27, 2005
Broken Road......
Did you pry it from the front, or hit it from the back side??
Old Jan 27, 2005
pon55's Avatar
My daddy always said, wack it!
Old Jan 27, 2005
pon55's Avatar
I did mean the center cap!
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
technosilver
Nov 14, 2001 10:58 AM
MooCoW
Nov 9, 2001 05:22 PM
