ABS light on
ABS light on
I tried searching older threads to see if anyone had asked this question before. I didn't come across anything so I'll go ahead and ask. Whenever I hit a bump in the road (like a sewer cover) with the drivers side front tire my ABS light goes on. This is the second time it has happened to me. When I turn off my car and turn it back on the light goes off. Does anyone else have this problem or know what might be causing that light to come on?
Its a celebration bitches!
one of the sensors is lose or out of place, check all 4 sides and see if its in properly.
i had the same problem when i got rear disc's my light was on and found out it was the rear left abs sensor, it fell out...
btw you are going to have a abs light when on a dyno, your front tires are at a diffrent speed than your rears...
conspiracy90
Jun 7, 2023 01:01 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
