Tire presure
Old Jan 2, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Tire presure
What would be the ideal tifre presure for street, on 205/55/16 Falken Azenis tires, and what would it be good for Auto-X
Old Jan 2, 2005
Zzyzx's Avatar
Autocross Junky
For the street 32 front 30 rear..... WHen I autocross I run 37 Front 33 Rear, but then I'm running a good amount of Negitive camber on the nose. Before I was running 45 Front and 32 rear.
Old Jan 2, 2005
standalj's Avatar
standalj should not be trustedstandalj should not be trustedstandalj should not be trusted
How do you determine the right amount of pressure in your tires when autocrossing?
Old Jan 2, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Ideally, with a pyrometer. When you have even tire temps across the tire, you got it right. The way most people do it is with a shoepolish mark on the outside. When you're rolling the tire over to the top of the triangle that indicates where the wear bars are, you got it close enough. The rears are on feel.
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
