Wheel stud missing
Old Dec 26, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
Wheel stud missing
I'm looking to buy some rear brakes off the SI and the set that has my interest has a problem with the wheel studs. one of them was pulled out of its spot. Is there a way to fix that? or is that brake assembly just shot? thanks in advance.
Old Dec 26, 2004
O3CivicSi's Avatar
I love the cawk! Have you seen my baseball?
O3CivicSi is an unknown quantity at this point
Wheel stud
no dude that is an easy fix, but a new stud at honda or take one off of your drum brakes, beat the old one out with a punch and use some washers and a wheel nut to pull the new one in place.
Old Dec 26, 2004
low04's Avatar
low04 is an unknown quantity at this point
like he said easy fix maybe at most 10 bucks to fix
Old Dec 26, 2004
Shlomo's Avatar
so how is the stud actually held in place?
Old Dec 26, 2004
low04's Avatar
basically take the drum cover punch it through, put new stud through backput cover on, put a wrench up against the drum put lug nut on an hammer it on until it seats all the way and then you will be good to go
Old Dec 26, 2004
Shlomo's Avatar
the studs allready gone, so the only thing i'd have to do is take the new stud and hammer it into the hole, no screwing involved?
Old Dec 27, 2004
_Viper_'s Avatar
No screwing in involved just hammer that **** in
Old Dec 28, 2004
Shlomo's Avatar
cool, thanks
Old Dec 28, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
pound that s.o.b. with a hammer and you set
Old Dec 28, 2004
pon55's Avatar
Thumbs down
Lug studs should be pressed in not HAMMERED!
Pulling it in with the nut and washers is the best home method.
B4 you jump, you can hammer a lot of times,but once in a while it will not seat correctly. ( and you don't know it till you try to take the nut off)
Old Dec 28, 2004
Shlomo's Avatar
so what ur saying is that i should take it to a shop to have it put in?
Old Dec 29, 2004
pon55's Avatar
As o3civicsi said, use the lug nut and some washers to pull the stud in.
Old Dec 29, 2004
SIinthesky's Avatar
I've used the hammer method for about 8 years and have done countless wheel studs and never have I seated one wrong......but....do what you want.
Old Dec 29, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Lug nut method works great. Pounding puts a lot of stress on the parts.
You want a lug? I did the swap and bought an extra set, so let me know.
Old Dec 29, 2004
87MugenProCR-X's Avatar
87MugenProCR-X is an unknown quantity at this point
either method will work. afterwards when you put your wheel on and tighten upthe lug nuts its going to pull the stud to where it needs to be.
julian
Old Dec 29, 2004
Shlomo's Avatar
how much are lugs?
Old Jan 1, 2005
98oRange's Avatar
98oRange is an unknown quantity at this point
i just beat the **** out of them.
EM_WON
Jul 22, 2015 06:49 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
