plz help me with tires
Old Dec 18, 2004
kkk's Avatar
kkk
kkk has a little shameless behaviour in the past
am planning on putting 18's on my civic
tire size is 225/40/18
i have allwaz had a problem with low profile tires....
the tires swell from the sides .. any idea y is this???
i have been running 215/45/17's so far and had problems with every tire i ever changed ..
this time i am planning on putting 18's but would want to take any risk since the tires are really expensive!.
air pressure in my tires are 24 ps i think. (or mayb psi)
and the road where i live have really big potholes everywhere
Old Dec 18, 2004
VTECTypeR's Avatar
If you have really big potholes everywhere maybe you shouldnt get 18's. And also you should put about 32 psi in your tires not 24.
Old Dec 18, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
whats up with your name??? (kkk)
i have 215/40-18 and have not had a problem.
Old Dec 18, 2004
Mr.Modify's Avatar
hmmm yea kkk? wtf?
you can't avoid potholes?!?
Old Dec 18, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
tire bubbles=cheap tires...
dont be atight *** and get nice tires they will protect ur wheels....
also mr KKK. id change ur name ..kinda offensive or put a disclaimer under it.. if it means something else
Old Dec 18, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
i have had like 15 sets of 215/35/19 and not one problem.. but when i used to have some cheap *** tires i had problems w/ bubbles.. lemme guess u run khumo?
Old Dec 18, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
24 PSI?! I wouldnt even do that to the steelies...... 34 PSI is more like it.
Old Dec 19, 2004
armjr2's Avatar
armjr2 is an unknown quantity at this point
the problem is ur running too low of a pressure in ur tires i have 215/45/17 running about 35 psi and their fine hit many pot holes w/ no problems (not aiming 4 them they just appear). try increasing the air pressure, 24 psi dang the stock wheels call 4 at least 30 psi. ur having trouble w/ 17 and u wanta go bigger hhhhmmmmmm i guess that the american way bigger is better
Old Dec 19, 2004
kkk's Avatar
kkk
i am running yokohama avs sports ..
i shold add in 30 psi?? isnt tht too much for a 40 profile tire?? cause the stock tires are 65 and they have around 30+ in them
Old Dec 19, 2004
XxSoVeReiGNxX's Avatar
I dunno guys. kkk's a legit name. It's an organization name, just like Walmart or McDonalds and I bet most members would not object to a member having a name like those 2. Its not as aggressive/offensive a name like "FordFocusSucks" (sorry for pointing you out guy, i got no beef).
...as long as he doesn't put "black people and minorities suck" in his signature or something. This site's had its share of bigots
As for tires.. I run meaty 225/40s cause of the road quality around my area. I still got pressure bubble from a pothole doing 45...
I had 215/35s on my old 17" rims and bent the hell outta one of them one day. Which is why I went to 225/40
SidCivic
Oct 3, 2015 06:00 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
jody501
Jul 10, 2015 11:01 AM
