Tire rub
Old Nov 23, 2004
stracer's Avatar
stracer is an unknown quantity at this point
Tire rub
I was wondering, my friend has some 18's he wants to sell me, but they have 215/35 18 nittos on them. He said on his 4 dr. sedan that they rubbed in the back cause he has springs that dropped it like 2.7. I have the neuspeed sports that claim 1.8, but they seem a little lower than that. So does anyone have the same suspension set up with the same size tires that will let me know if they rub anywhere.
by the way they are silver Konig Verdicts, do you think those look good on a 04 silver coupe.
Old Nov 23, 2004
TeLLy's Avatar
Yes, it's an Acura EL
215/35/18 tires are about the right size for your car, they're only 1.3% bigger than stock, so there shouldn't be issues there unless you're really slammed or the offset is way off the 40-45 range. My rear was slammed last year past 2", and I had 215/55/16 winter rubber on there, didn't rub.
Silver rims will always look OK on a silver car. The current trend (which I like) however has been to add a little more contrast by using black or gunmetal rims on a silver car.
Old Nov 23, 2004
VietScouty's Avatar
VietScouty is an unknown quantity at this point
Another solution but I would not recommend it. Cutting out the inner fender so it doesn't rub.
Old Nov 23, 2004
itskalvin's Avatar
itskalvin will become famous soon enough
why would you suggest cutting out the inner fender? maybe roll the fenders in but dont cut it out
Old Nov 23, 2004
VietScouty's Avatar
Well itskalvin, my friend did it to his accord when he lowered it too much...it begun rubbing on his inner fender so he ends up cutting it out to stop it from rubbing. Only major downside of it is if the tires get wet or muddy, it smacks all of that dirt and everything into the engine bay.
Old Nov 23, 2004
zachgeyer's Avatar
too big
Old Nov 23, 2004
Jeff B's Avatar
Jeff B has a little shameless behaviour in the past
I am not sure why my wheels rub but they do. I have 215/45/R17's and the right front strut tower rubs a little when I go over big speed bumbs and when I turn the wheels all of way, the front tires rub on the sub frame. I have been considering getting 40's instead of 45's.
Old Nov 24, 2004
stracer's Avatar
Its cause you have need to change it to a 205/45 or 215/40 for 17's
Old Nov 24, 2004
Zzyzx's Avatar
Autocross Junky
I run 215/45-17's for the street and the only time I rub is when I'm at full lock turning hard...
Setup:
Eibach Sportlines on Konis...
when i race I never rub either... But then I'm on 205/50-15's (that actually measure out to about 218-220)
SidCivic
Oct 3, 2015 06:00 AM
cukaracha
Aug 29, 2015 05:27 PM
mikey1
21
Aug 27, 2015 06:38 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
