help!!!!! problems with bearings
Old Nov 15, 2004
yellowgqthug817's Avatar
yellowgqthug817 is an unknown quantity at this point
My car on the driver side is making a warping noise... Yesterday i went to get my car alignment and after he finish it he told me my bearings was probably messed up on the driver side.... Does anyone know if the bearings is still under warranty if i bought my car in nov 2001 and right now it has 45,000 miles. And if i wanted to change the bearings myself how hard would it be.
And when the bearings are changed would i have to get another alignment......
Old Nov 15, 2004
PunkingCivic's Avatar
I need TP for my bunghole
It depends what bearing are you talking about.
If it the wheel bearing then you would have to take it apart and have the old bearing pressed out. and the newone pressed in. Don't attempt to do it your self you'll jack it up!
Yes, you will have to have the alignment done again. I would highly suggest getting the alignment done after messing with any aspect of the suspension.
go here to order them probibly cheaper than the delaer: http://www.hondaautomotiveparts.com/...catdisplay.jsp
Old Nov 15, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
shitt!!! mine makes a strange noise in the back right tire. i only have 15K on the car, however I have aftermarket shocks and wheels. Will they still cover it
Old Nov 15, 2004
yeah it's the wheel bearings
GolNat
Suspension DIY
May 12, 2022 06:49 AM
reqy
Jun 1, 2015 07:05 AM
oqjoi
Transmission
May 6, 2015 06:27 PM
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
