gonna get some drag tires
Old Nov 5, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I don't want drag radials or slicks ... because it's a very far drive to the nearest track ... and seeing as how it is winter, I don't want it to start to rain while going there ...
so help me choose:
1 - Goodyear Eagle F1 GS-D3
2 - Falken Azenis Sport
3 - Bridgestone Potenza S-03
4 - Michelin Pilot Sport 2
5 - (wait until release) Falken Azenis RT-615
6 - BFG g-force T/A KD
to give you an idea, it's gonna be from the following sizes ... 215/40/17, 215/45/17, 225/45/17, 225/40/17 ... depending on which tire and availability
specifically, I'm looking for a drag/straight line tire ... and sometimes for street. Need not be good with cornering
(please don't automatically jump to the azenis sports because you 'heard' it's good)
Old Nov 5, 2004
civicvtec1ps's Avatar
Search and Learn
Currently using Yokohama evs and they are great tires.
Not bad for drag racing, i pull 2.2 consistantly.
Falken Azenis are not great for drag racing.
Old Nov 5, 2004
jttegx's Avatar
OMNES AD UNUM
i heard the azenis sports was good lol jk
i would snoop around tirerack and other popular tire sites too see reviews of customers expierences
Old Nov 5, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I have ... and I pulled up the few options that I liked.
Old Nov 5, 2004
icebergslim's Avatar
BOOSTED HYBRID
icebergslim is an unknown quantity at this point
s-03's
Old Nov 6, 2004
Ed's Avatar
Ed
Mm, S-03s.. they sound expensive though, but i don't know how much the other tires run either.
Old Nov 8, 2004
HondaLuver's Avatar
Its a celebration bitches!
dude, the Goodyear Eagle F1 GS-D3 is one of the best tires ever made. they are so good that 99 percent of all cop cars out there use them. i want to get these.. these apparently have the best traction in wet and dry
look at tirerack.com
http://www.tirerack.com/tires/tires....omCompare1=yes
Old Nov 9, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yeah, I used to have those for my turbo in 225/50/16 ;P
they were really really good ... never ever chirped even with I launching or shifting ...
I don't know .. if there's one that's better for drag though, I'll take it. .. I'm looking for tires for some new rims that I'll be getting in the future ;P
Old Nov 9, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
an idea! get some front slicks and load them in the trunk on the drive there. unpack them and your good to go.
Old Nov 10, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
I agree, you will NEVER get the traction of a drag radial or slick with a street tire, and the street tires are usually more expensive. Just pack them and change them at the track (or drive, if you are going to the track you shouldn't be worried about it raining in the first place...)
Old Nov 11, 2004
djmota's Avatar
i'll give a to the azenis. they are great for autocross but not so good for drag. They are too heavy, and the sidewalls are too stiff.
Old Nov 11, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
the idea is to goto the track on a cold day ... better times
djmota: interesting info ... I've heard more good things about azenis and dry traction than bad things
Old Nov 12, 2004
Zzyzx's Avatar
Autocross Junky
The big problem with the Azenis as a drag tire is the stiff side wall... Seriously, Falken put steel belts in the side walls to reduce tire deflection while turing... so you are reling entirly on the tires soft compound to give you good launches (Because even with low psi, the side walls still dont flex). Now if falken decided to make a Drag tire with a soft side wall and the same compound as the Azenis.... that would be a really good tire for drag.
Old Nov 12, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hm, so I take it soft sidewalls are good for drag? ... that would make the goodyears a very good drag tire...
Old Nov 12, 2004
djmota's Avatar
correct. i made the mistake of dropping air pressure below 22 and just spun the whole 60ft no matter what i did with the throttle. I am running azenis at the track. They are not bad for drag but there are better choices out there. If I had to do it again i would have bought some bfg's drag radials for dragging. As far as conering traction goes they kick ***
SuperNova18
24
Sep 2, 2019 10:46 PM
mikey1
21
Aug 27, 2015 06:38 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
krazykoncepts
Jul 14, 2015 01:55 PM
