mix matching tires
Old Oct 3, 2004
jttegx's Avatar
OMNES AD UNUM
mix matching tires
the time hasnt come yet but i want to clearify for the future.
right now im running 195/60/15 bridgestone potenzas on all 4. when the 2 front tires start to wear down and become faulty, would it be ok to slap on 2(two) different tires, but the exact same size? 195/60/15.
my future tires:
2 front "falken ziex 512" 195/60/15
2 rear "bridgestone potenza re950" 195/60/15
if not, why?
thanks
Old Oct 3, 2004
FingerJ's Avatar
FingerJ is an unknown quantity at this point
why not i run differnt tires and rims (of the same size) in the front during the winter.
Old Oct 6, 2004
Roo's Avatar
Roo
Roo is an unknown quantity at this point
It should be safe enough to run different tires in pairs. IE: fronts must match and rears must match, but not all 4 must match.
Imagine the horrible handling if your two fronts did not match.. breaking / road grip would be uneven leading to very dangrous situataions.
Roo
Old Oct 6, 2004
jttegx's Avatar
OMNES AD UNUM
yeah, of course the 2 fronts and/or 2 rear tires will match.
i know some guy with a prelude who has 4 complete different tires.. when i jacked up his car, it was slanted sideways and as i was jacking it up, the left side would raise up before the right.
plan: 2 falken tires up front (same size/model)
2 bridgestones rear (same size/model)
Old Oct 6, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Why don't you rotate your tires every 7000 miles so they wear even, then you go and buy 4 new ones like you're supposed to.
Old Oct 6, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
^Yeah, why are talking about 2 new front tires only? Just rotate em. Plus, didn't you just get those potenzas?
Old Oct 6, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
You'll be OK, BTW if you buy 2 new tires they should be going on the rear.
Old Oct 7, 2004
jttegx's Avatar
OMNES AD UNUM
i thought i would save more tire in the long run if i only replace the front ones when the time comes. that way im hardly changing the tires in the rear. so i'd only pay for the price of 2 tires to replace the fronts and not worrying about the rears.
its hard to explain.. err =\
Old Oct 8, 2004
Jap-Euro Fusion
You won't save a dime. If you completely eat the fronts, your tires will probably last 1/2 as long as they say. So then you go buy another set, just use them on the fronts, now you've got to buy 4 new ones because the rears have run their miles out. So now you've bought 6 in the time you should have only bought 4 had you rotated them. Always rotate your tires.
Old Oct 8, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
AMEN BROTHER !!
Boil is dead on... rotate your tires. else you loco.
However if you have a tire burst or wheel just happens to fly off the car while you are driving down 95. then yeah having a different brand tire won't make a big difference... get the same size of course.
Old Oct 10, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
this may or may not be relavent with this thread, but I'm planning on going with snow tires on the front, and stock firestones out back in the winter. Would that be ok? It would be same rating for tire size and rim size.
Old Oct 10, 2004
thoughthard's Avatar
thoughthard is an unknown quantity at this point
I do that on my non-7thgencivic. Yokohama Guardex 600 on the fronts, Kumho ECSTA 716 HP4 on the rears. I have done that since I got the car new back around Christmas 1991. Various snow tires on front, and various all seasons on the back.
Most places will recommend snow tires on all fours. That is the best idea though. With just snows on the fronts, just watch out for the rear getting loose on turns. The stock Firestones blow on any wet road, so I am presuming that they blow on snow and ice even worse.
Old Oct 10, 2004
OK, thanks, I'm pretty careful in the snow... and I know how much the Firestones suck..... but I'll give it a try when snow comes around.
Old Oct 11, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
the new tires should go on back...
alaga
25
Aug 13, 2015 04:42 PM
spyder13
Jul 31, 2015 06:31 PM
