Brake Bias....
Autocross Junky
Rep Power: 356 Brake Bias....
Ok, so at the last autocross I noticed that when I'm threashold braking the tail wanted to get a bit squirly. One possible reason for this could be the brake bias. (among other things, such as alignment ect...)
I'm thinking that I have too much brake bias on the rear, causing the rear end to want to lock up before the front, which makes the rear end unstable.
Right now I'm running Porterfield R4S pads and shoes. So I'm thinking of going to a less grippy shoe to help stabilize the car under heavy braking.
any other Ideas?
any other Ideas?
Rep Power: 457 Couldn't you just toss in one of those Golden Eagle brake bias controller thingies and adjust it for track days?
Jap-Euro Fusion
Rep Power: 400 You don't want to hear this... but put more weight in the back. Leave the spare in, fill the tank,etc..... give it some more downward push to keep the wheels spinning. That'll give the brakes some more mass to slow down, lessening the chance they'll lock on you. Another option may be taking out some air from the tires, but then that starts screwing with the handling too.
Less grippy shoes may be the best option, although I don't know what runs between porterfields and OEM. I'm still running OEMs with the Axxis pads in the front, I don't think I've ever felt squirlyness under breaking (not sure exactly what I'm looking for on that), but they seem to stop the car. I was under the impression the majority of the braking was handled by the fronts.
Autocross Junky
So esentially, when you get better tires, you actually want LESS braking power on the rear end...
And I'm not 100% sure it is a brake bias problem, as the ABS wasnt going off. It may have been just me causing it, by making slight course carections while under heavy braking.
Bricoleur
09-09-2015 06:48 PM
thaler4cuse
09-07-2015 08:25 PM
Josh 1973
09-07-2015 10:10 AM
