Help with Brake Problem
Old Sep 11, 2004
scarpones's Avatar
scarpones is an unknown quantity at this point
This is my problem.
When im driving, any speed, a load squeeking comes from the front passanger side. I think it's the brakes, but it doesn't happen when i apply brake pressure. Its random and doesn't really have any pattern to it. When i press the brake, the squeeking usually goes away, but comes back pretty quickly.
Any ideas?
Its a '02 lx coupe with 75k and on its first pair of brakes.
Old Sep 11, 2004
streetglower's Avatar
Well if it doesnt happen when you apply the brakes then its not a brake related problem.
I really am not sure though what it would be. Can you explain it better?
Old Sep 11, 2004
scarpones's Avatar
Say im driving, out of no where, i hear a squeeking noise, which sounds like its coming from the brakes. Then it will just stop, then come back again in pulses
like....eeeee....eeeee....eeeee......eeeeee..
if you can sound that out, you will know what i mean.
the squeek sounds like a worn out break squeek.
Old Sep 11, 2004
Well if it was worn out brakes, it would happen when you applied the brakes, but you say it happens when you dont apply the brakes.
Not sure though, I wish I could hear it, cant really sound that out to well. LOL
Old Sep 11, 2004
scarpones's Avatar
lol...
when i brake, it does squeek..but not as load. Im gonna replace the pads anyways tomorow, got the set for 40$ so i might as well.
someone was telling me it could be seazed brake pistons, and its constantly clamping the rotors, which is probebly gonna be a pain the *** to fix.
Old Sep 11, 2004
if you have a seized brake piston, basically seized calipers, all that needs to be done is to have them rebuilt. I had both my calipers rebuilt for $50. Just take off your tires tomorrow and check everything. If your pads arent wearing evenly, then you will need your calipers rebuilt. And possibly your rotors resurfaced.
Old Sep 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
actually brakes that are worn at an angle will cause a squeek as driving down the road and when you apply the brakes it will pull the wear indicator away from the rotor and the noise will go away..... Get the brakes checked!
Old Sep 16, 2004
2K1Civic17"Gabe's Avatar
rotors or pads should be the problem
conspiracy90
Jun 7, 2023 01:01 PM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
