Spare tires?
Just wondering... for those who has the 16" or greater wheels, did u get a 16" or greater spare tires too? or can u use the OEM spare tires when u get a flat tire?
Originally Posted by Zzyzx
The rim size means very little... the overall diamiter of the wheel/tire combo is whats important.
Autocross Junky
Originally Posted by Solidus
ok so if i blow one of my 18" tires can i put the stock spare on? Would that be bad for my allignment or anything?
Esentially, Remember that the spare is designed to work with the stock diamiter wheel/tire which for my EX is 24.49 inches... as long as your wheel/tire combo doesnt deveate from that too much then you shouldnt have a problem.
Originally Posted by HomerSimpson
I got a flat on one of my 17's and used the oem spare. The car pulled toward the side with the spare but it worked
he is saying tire/wheel combo should combine to be the same size, IE. bigger rim = smaller tire, smaller rim = bigger tire, so if u put stock 15s w/ stock tires side by side against a 16/17 w/ smaller tires the height would be the same or VERY close..
so as long as the height is about the same, it shouldnt hurt anything because it should be the same height as stock, im not sure if width would change things or not, im assuming it doesnt..
Originally Posted by davidoff1
ok thanks a lot guys...
but wat if the wheel n tire combo is 1" bigger than stock? would it be ok to use stock tire?
i would just use my stock 15" wheel for a spare, i'm running 18" rotas on Ground controls with Xenon kit, and if i were to use the oem spare, i think my kit would be on the ground, lol.
Just to be safe, I would put any spare on the back, if possible. Less things to worry about like mechanical damage, weird steering, ABS problems, etc. Could be a hassle along the side of the road though...
Strycker
Aug 18, 2015 02:25 PM
alaga
25
Aug 13, 2015 04:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
