popping sounds coming from front wheels..
Old Aug 6, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
what could it be? its only at certain times and its from fronts only while their moving
knuckles?
bearings?
my CV joints are fine..
i just wanna know what the hell the noise is. i think it has something to do w/ steering cause if i drive 300 miles on thre highway as soon as i get off and i go for a slow turn it goes pop pop pop pop pop its not suspension its something else..
riley
Old Aug 6, 2004
XTREME2K2CIVIC's Avatar
Reppin Stage 7
I got that same thing...First off make sure the rims are nice and tight... Other than that I dont know... I blame it on aftermarket suspension.. Can expect it to not make any sounds...
Old Aug 6, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
my B&G's have done that ever sine I put them on, except its only when i turn the wheel all the way going real slow (like pulling out of the driveway or something)...
my teins never did this ****, but they also didnt go as low so I cant complain. haha
Old Aug 6, 2004
zen_master's Avatar
i got a it of pop noises after i installed my neuspeed strut bar..
dunno if it's the same noise..
it's only when i accelerate from 0 to 5 mph though...
is it possible that because i jacked up my car while the nuts from the studs were being released might caused this problem (i was installing my strut bar)?
is it possible that what i did "damaged" the coils and/or anything on the wheel?
Old Aug 6, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
^^^ doubt it.
Old Aug 6, 2004
zen_master's Avatar
^^ thank God if it's not true..
Old Aug 6, 2004
matrix311's Avatar
matrix311 is on a distinguished road
i have the poping sounds on my car to, if i go liek 5mph it makes a loud popping sound from the front right of the car, pretty sure the tires are on tight, so not sure. I'm putting in another new suspension tonight, so hopefully it goes away.
Old Aug 6, 2004
shmik1's Avatar
my old car popped on turns going slow too, it was the tie rods, no idea if this is the same problem or not...
Old Aug 6, 2004
zen_master's Avatar
maybe i should do allignment.
Old Aug 6, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
how can this problem be relieved obviously its B&G since
juan
me
eli
have the prob.. lets talk to MEX B&G god..lol
riley
Old Aug 6, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
maybe some lithium grease would help.. like just compress the springs undo top mounts.. and then lube her up?
riley
Old Aug 6, 2004
Solidus's Avatar
IM RICH BIACH!
Solidus is on a distinguished road
I have had my new suspention on for months and never had any problems. Just a couple days ago it started that same popping noise. Im convinced its the tie rods
Old Aug 6, 2004
streetglower's Avatar
if you are all getting popping noises, check your CV Joints.
Old Aug 6, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Its not that, it didnt do it till I installed the B&G's (went from Tein SS earlier that day)
I dunno- im going to go and retighten some **** cause I got my second wrench now (didnt have wrenches before to tighten)...
Old Aug 6, 2004
it also might be something rubbing on something.
Old Aug 6, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Well, Me, Juan, and Riley are all tucking all 4's...So thats possible too....
Old Aug 6, 2004
Zzyzx's Avatar
Autocross Junky
Is it a pop or a click??? check your tires for nails or rocks stuck in the tread.....
Old Aug 6, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
no nails.. its more of a click..
riley
Old Aug 6, 2004
its probably just something rubbing, if you have had it for a while and it isnt doing any harm, then I wouldnt worry to much about it.
Old Aug 6, 2004
sspem2's Avatar
em2
no noises here.
Old Aug 6, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
maybe thats cuz were lower on our B&G's than you?
idk..
riley
Old Aug 6, 2004
Zzyzx's Avatar
Autocross Junky
Check to see if you center caps are on tight... If I dont tighten the center caps on my axis Se7ens they make clicking noises...
Old Aug 6, 2004
sspem2's Avatar
em2
ummm no riley. im dropped all the way jsut like u. no threads on front and only like 4 threads in the back.
Old Aug 6, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
oh,.. not center caps, not wheels loose, id what it is.. i keep thinking bearing? when i accelerate it goes faster too. and its only while wheels r moving.. so its a rotational problem
Old Aug 6, 2004
trance4mer's Avatar
trance4mer is an unknown quantity at this point
i get a popping sound when im at a dead stop or rolling like at 2mph and turn the wheel. only from the front tho. started ever since i got my new springs...
Old Aug 9, 2004
umboutwo's Avatar
umboutwo is an unknown quantity at this point
its definitley your wheel bearings, i had the same rotational noise
took it to honda and they replaced the wheel bearing free of charge.
after i had no more noises. As far as the poping noise its still there and i havent figured that one out yet. BY the way i am lowered on koni/groundcontrols so its not just the b&g's making the poping noise.
Old Aug 9, 2004
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
i have the same thing too.. but when i put my stock tires back on, the poping noise goes away.. and yea i only here it when i'm going real slow.. like turning right into a parking lot, or comming from a parking space like mc donalds..
Old Aug 9, 2004
sw388integra's Avatar
i have something similar when i'm downshifting and esp. when going into 2nd from 3rd...i thought it was from being 3.5 inches down!!
Old Aug 9, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
it's your springs! it is to compressed that when you roll either it seperates the coil from sticking to each other and or it's tapping the coil when you are moving that causes the tapping noise!
if you have the coilovers it's that metal in the middle that sleeves down to the struts that taps to the shocks body... you suppose to have that rubber "O" ring so it would touch the body of the shocks
I had the same problem with my tein basics, the plastic sleeve that covers the metal pipe that connects to the shocks to prevent dirt to get into them... is where the popping came from, then later it just went away... you need to break em in! or change the "O" ring if it's busted!
just my .05 from my own experience!
Old Aug 9, 2004
ImportGrl's Avatar
ImportGrl is an unknown quantity at this point
i have all stock suspension on a 2k4... i also get these popping noises... im worried something is wrong
