Replacing my wheel stud...
Old Jul 14, 2004
Seabass's Avatar
Seabass is an unknown quantity at this point
Hey everyone, ok i need to replace one of my studs for my 01 civic, the studs you use to bolt your wheels onto the car, theres 4 of them, 1 of them broke in half so i need to replace it, i would get it done professionally but they want $70-100 just to put on this $1.50 stud. So can someone kinda walk me through it and help me out? Thanks.
Old Jul 14, 2004
streetglower's Avatar
unless you have the tools and knowledge, let a shop do it because if it is in the front, you have to remove the hub assembly that is why it is so expensive. Most older cars you could just knock the bolt out, but now in order for us to do that it gets complicated.
Old Jul 14, 2004
Seabass's Avatar
its not the front.....its the back, im gonna do it later on tonight, is there anything i should know before i do it? Thanks.
Old Jul 14, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
its easy as f.cuk
take off rear wheel...
make sure ebrak is not on
pry off the hub(nothing holds it on.. it shoiuld come right off
hammer out ur broken one...
stick new one in from back (make sure its 12x1.5)
stick like 10 washers on it... and put a lug on... put a tool thru one of the holes to keep it still and tighten the lug all the way (it'l pull the stud thru the backing plate)
then put hub back on... and done.
riley
Old Jul 15, 2004
Seabass's Avatar
Talking
Thanks riley, did it today, saved myself 70-100 dollars, appreciate the walkthrough.
Old Jul 15, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
yep anytime..
supra8311
Sep 16, 2015 02:07 PM
anddrrey
May 11, 2015 02:30 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
