will 215/45/17 with neuspeed sports rub??
Rep Power: 0 will 215/45/17 with neuspeed sports rub??
I am thinking of buying some neuspeed sports for my 02 sedan. Here is what I have
17" x 7" rims 40mm offset
215/45/17 tires
I am going to purchase some neuspeed sports springs and a rear camber kit to fix the camber after lowering.
Anybody out there have this setup?? Will I have a problem with rubbing??
What if I change my rubber to 205/45/17?? Will this solve the problem??
Thanks in Advance
215/45/17 tires
Thanks in Advance
Rep Power: 0 It won't even be close to rubbing. I had Neuspeed Race springs and 215/35/18 and I didn't rub. You have nothing to worry about. A camber kit isn't even really necessary, either, you usually only want one if you drop more than two inches.
I Queef > You
Rep Power: 0 The rears will rub occasionally when you turn, but usually nope. Depends on your camber too. 205/45/17 would be great! Would look great with Neuspeed Sports too. I have Sports w/ 205/40 and they look good, but a little too thin, therefore more noticable wheel gap. 215/40 or 205/45 will be my next set.
1 Post
Rep Power: 271 Had 215/45/17 with 40 mm offset, i had to get a rear camber kit because they were way off alignment and they were ruining my tires. I then rubbed on every single turn with the camber corrected. If u wanna wear ur tires unevenly don't get a camber kit, but if u do get one, your tires will rub. I had to get 205/40 tires and have had no problems.
cuz i'm about to get those sets of tires
Touge
09-23-2015 10:51 PM
