Did anyone ever remove the "slider" pins?
Old May 10, 2004
pinkytube's Avatar
pinkytube is an unknown quantity at this point
I did not phrase my previous question properly. The slider pins I am having trouble with are the ones the caliper slides on, not the bolts that actually hold the caliper on. I pulled the pins out of the "torque member" ( the piece you have to remove to get the discs of which the caliper rests on); I find it almost impossible to put the slide pins back into the bracket. One of the pins has a tiny rubber gasket on the bottom of it, and the other one is a regular one. It seems like I always get air trapped in the bottom ove it, and when i try and force the oins in, they won't go in all the way. But if i don't put grease on them, they go in fine, but I HAVE to put grease on them in order for them to function properly no? Any suggestions?
Thanks
7thgensurvivor
Aug 26, 2015 06:17 PM
ek_rebuild
Aug 11, 2015 08:00 AM
greenbackz
Jul 30, 2015 12:04 AM
DerbyDad03
Jul 27, 2015 11:34 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
