DIY: Brake Surgery (then make them bleed, then put them to bed)
This is an alteration to Grey's DIY. It was useful, but if your brakes are like mine... totally uncooperative, then this is your DIY.
You need:
--2 new rotors, 4 new screws (hope the rotors come with them, they're 6mm if they don't, but have a non standard head)
--A set of front brake pads
--Anti-Squeal goo
--Brake cleaner
--Brake fluid
--WD-40 type stuff
--2 8mm bolts
--A power drill capable of drilling through metal (I'd say 14.4V cordless or more, or get a corded drill)
--Assortment of drill bits smaller than 1/4" (HSS is fine, Tungsten Carbide is better)
--17mm socket
--10mm wrench
--8mm wrench
--2' of 1/4" OD flexible tubing
--1 empty deli salad container
--1 funnel
--lots of towels
--4 jackstands
--1 jack
--ball of string or wire
-- 4" C-Clamp
-- Torque wrench
--Breaker bar (for wimps only)
Now, it seems like a lot of ****, but take my word for it, you need it all, so just make one trip the hardware store, and not 3 like I did. That just wastes time when you could be beating up the car.
Now keeping in mind that this is the thread for those already pissed off that nothing works, we're going to skip all conventional methods and move straight to destruction. But PAY ATTENTION. Somethings you can destroy, others you can't because you have to reuse them.
Put your safety glasses on, here goes.
Remove the caliper by removing the 2 17 mm bolts on the back of the hub. This is where the wimps need the breaker bar. Bottom one first, tie the caliper to the spring. Undo the top one. I found it useful to rest the caliper flat on the jack foot rather than letting it hang. It also makes me feel better than letting the brake line flop around. Remove the outer pad by pushing inward, it'll just slip out. The shim behind the pad comes with it, save that, you need to reuse it. Then take the C-clamp and push the piston back in by clamping the back of the piston cylinder and the face of the OLD inner pad. Once done, remove the inner pad. Clean the whole thing with brake cleaner. Apply antisqueal goo to the BACKING PLATE of the new outer pad and a little on the back of the inner pad. Follow the directions on it, mine said to wait 10 minutes for it to tack up. Then put the shim on the outer pad, press them together and wipe away excess goo. Then put a little goo on the back of the shim and put the new pads in the caliper, inner one first. Set the caliper aside for a minute. Now... the stupid rotor. Forget saving the screws. Get out the drill, start with a 1/8" or so bit, go about 1/4" straight into the center of the screw head. Its important you center it, this is your pilot hole for later. Then keep increasing the bit diameter until the head breaks off. You should be able to pull the rotor off. If you can't, you'll notice there are 2 threaded holes at 90 degrees to the screws. Put an 8mm bolt in each one, then turn them in and you can press the rotor off the hub. You may need to do this if the rotor is rusted on. If you don't feel like buying 8mm bolts, then the ones that hold the brake line to the strut happen to be the right size. Now that the rotor is off, put the 1/8" bit back in and drill all the way through the remaining screw stub. Don't drill the hub though, just hit the screw. Thats why being straight was so important. Somewhere along the way, you'll hog enough of it out that the drill will snag and turn the stub out the back of the hub plate. No more screw and the hub is still fine.
Clean the hub with brake cleaner and some WD40. Put the new rotor on after you've cleaned it with brake cleaner, use 2 new screws. They're not really necessary, the wheels (well, the lugnuts) hold the rotor on, but they're for piece of mind. I put a dot of Loctite BLUE (NOT RED) on them just to be sure, and FYI, heat releases loctite... for those of you who have a propane torch but never get to play with it. Then put the caliper on. The pads should be spaced enough if you depressed the piston all the way back in.
Torque the 2 caliper bolts down to 170 N-m or 125 ft-lbs... which ever you want.
Rinse and Repeat for the other side
Bleeding
This is the other part... this hasn't been covered I don't think.
Jack the whole car up... front and back. Pull all 4 wheels. Locate the bleeder valves. On the fronts they're on the top of the piston housing towards the back side of the caliper. On the drums, they're inconveiently located right under the upper control arm bushing. Why Honda put them there, I don't know... you can't get to them easily and its a pain. Second bitching point, you need a 10 mm wrench for the front, 8mm for the rear. Again... why can't we standardize these things? Its not hard. I thought the Japanese were effeciency experts.
Anyways... you go with the one farthest from the Master Cylinder first. So right rear. Put the 1/4" hose over the end of the bleeder after removing the cap, aim the other end into the deli container, get someone to depress the pedal, crack the bleeder, close it, then release the pedal. You don't want to put the pedal to the floor... just about 75%. All you want to do is blow fluid through the system. Do it a couple times, then add more fluid to the reservoir. It is wise to use a different color fluid like ATE Superblue because the color changes when all the old stuff is flushed out. ATE also sells Type 200 Gold... which is Superblue but gold in color.
Bleed until you've got clean fluid and no air, Right Rear, Left Rear, Right Front, Left Front, make sure the reservoir is topped off (the MAX line), close it and put the wheels back on. Put the car down.
Bedding pads
"Bedding" pads into the rotors is done so you can transfer some of the pad material onto the rotor surface to increase the effectiveness. It also lets the pads work their way into the rotor surface much like piston rings do to the cylinder walls during break in.
This is just the most common method, it seems to work pretty good. You'll want to find some empty stretches of road to do it...
Accelerate to 50 mph, then apply the brake gently. Not just a barely touched it, but don't slam them. 40-50%. Go down to about 10 mph, repeat 4 or 5 more times. Then drive for 10 or so minutes and let everything cool down. If there's traffic lights, there's not much you can do, but see if you can just coast to them and not have to stop. Then run the car to 50, stop hard 5 times, 80% braking, down to about 10 mph. Then drive for 10 or 15 more minutes and take it back home. Let them sit and cool off, make sure everything is good.
At this point, unless you messed up, you're done. Be nice to the pads for 200-400 miles depending on how much stopping you do. This just makes sure they're broken in and worn into the rotors before you really rag on them. Then have at it.
You need:
--Anti-Squeal goo
--Brake cleaner
--Brake fluid
--WD-40 type stuff
--2 8mm bolts
--17mm socket
--10mm wrench
--8mm wrench
--1 funnel
--lots of towels
--4 jackstands
--1 jack
-- 4" C-Clamp
-- Torque wrench
Bleeding
Bedding pads
some pointers that may help others in the future....
1. always use an impact driver to remove the screws that hold the rotor on (no need to reuse the screws when done) if not you too will be drilling them out.
2. penetrating oil on the rotor around the hub and studs and use of a hammer lightly tapping the hub area can release the rotor from the hub.
3. believe it or not the use of one of those LARGE cheap generic gear pullers works if you grab the outer edges of the rotor and apply modderate pressure then tap the back side of the rotor with a dead blow hammer.
4. be sure to scrap ALL rust from the hub and inside of the rotor if reusing it, if you dont this can induce runout in the rotor and later cause pedal pulsations
5. when not replacing the caliper and pushing the piston back in to make room for new pads its best to losen the bleeder screw and push excess fluid out through it not the master cylinder. sometimes particles inside the system can be pushed back up into the master cylinder/ABS valving and cause all kinds of problems.
6. NEVER use channle lock pliers to push the piston in. Leave the old inner pad in against the caliper and use a C-clamp to make sure its even pressure pushing the piston in. If it takes LOTS of force to push the piston in.... REPLACE the caliper and save your self head aches later of a caliper failure.
A few other things i wanted to add reguarding bleeding. You should first suck out all the old brake fluid from the master cylinder and install new fluid. When you get to the bleeding part you will see the difference in old to new fluid while bleeding even if its not a tinted color of fluid
You should bleed all 4. The brake lines criss cross the car, so if there's a bubble, you stand the chance of just moving it from the front to the back if you just bleed 2.
I have no in progress pics, my hands were filthy.
There's this thing called the "no return valve" which attaches to the bleed valve. All you have to do is pump the brake pedal without needing to loosen and tighten the nut countless times. Not sure if it's easily obtainable at the hardware shop in USA.
this is awesome but I didn't understand something you mentioned about pressing the brake and making it bleed...no about the crack the bleeder. what is that? i thought once you removed the line from the caliper or the rear brakes the think starts bleeding?
Originally Posted by zen_master
so....we are allowed NOT to re-use the two screws on that rotors?
or...DO we have to buy new screws and re-install them again?
cos i think it's really a pain in the neck............
oh yea that too
you can reuse those screws, most time when you buy new rotors, they give you new bolts. Like someone else said, those bolts are just there for when they assemble your car, it holds the rotor on when moving down the assembly line. When you put your tire on, the wheel holds the rotor on.
tfnaaf, so your supposed to suck out all the fluid from the MC before starting any of the bleeding steps? you then add new fluid to the MC, then start the bleeding process? can a turkey baster be used to suck out the old fluid from the MC?
i just got done changing the rotors and pads and now i just have to change the fluid. thanks.
ThE FaMiLy SeDaN
well ima be doing my brakes feb 15th so wish me luck i think i got it pretty much down for now..
only thing is my brakes have 4 bleeder valves.. so i guess i bleed each one..
Originally Posted by orion_squall
Hi,
Therefore break fluid change= complete bleeding, so that if you do break fluid change it means bleeding is also done.
Suck the MC dry with a turkey baster or BBQ marinade syringe (something with a large capacity reservoir and suction, those are the 2 readily available things I can think of). Pour new stuff in, bleed brakes and continue to add new fluid to the MC as you go.
got2kids
May 9, 2015 06:45 PM
civic_gt
Apr 19, 2015 08:15 AM
