opinion needed
Old Mar 1, 2004
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
opinion needed
i'm dropping my car with edilbrock sportline springs... so the opinion i need is witch tire should i get. i'm thinking about a 205 tire so that it would be nice and thin.. but should i get a 215 so it would be more meaty???? which one would look best with the drop....
Old Mar 1, 2004
flotsamm's Avatar
I'm running on Eibach Sportlines with a 205/40/17 tire and 44mm offset wheel. I've never rubbed a fender, but then I'm not that low either. You might be able to get away with a 215 depending on your wheel offset. I'd say anywhere from 40-45mm offset should be fine, but you might want to get more opinions.
Be prepared for a harsher ride over the bumpy stuff! Dont get me wrong, I love my Sportlines but theyre 20-25% stiffer then stock. The prokit is 10-15% stiffer but a smaller drop.
Old Mar 1, 2004
oh okay thanks a lot...
jbradley4809
Apr 7, 2017 04:23 AM
Jokerhogan
May 9, 2015 02:52 PM
McD
Apr 16, 2015 10:46 AM
Myredjonda
Apr 14, 2015 07:00 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
