will 215/45/17 tires rub with lowering springs?
Old Feb 25, 2004
sf2ryu's Avatar
sf2ryu is an unknown quantity at this point
Smile will 215/45/17 tires rub with lowering springs?
Hi All, I have 215/45/17 Kumho Ecstas on my 01 Civic Sedan, and was plannning to lower the car with lowering springs (sport springs with a fixed drop size/not coil overs). Has anyone out there run a configuration like this and do the tires rub? If it rubs, does it rub only with full passengers or even when driving alone?
Old Feb 25, 2004
egot2da4th's Avatar
egot2da4th is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...threadid=94546
Old Feb 25, 2004
JayFReaZy's Avatar
depends how much you drop the car. I think with the 215/45/17 you can only drop maybe 1 to 1.5" without rubbing. Any more, your running the chance of rubbin them.
Old Feb 25, 2004
rckdrmr's Avatar
rckdrmr is on a distinguished road
as i mentioned in another thread... i saw a 7thgen with 215-45-17 with the eibach springs pro-kit, and it looked snug with no rub.
Old Feb 25, 2004
rei846's Avatar
rei846 is an unknown quantity at this point
It just depends on the offset of the wheels. I have 45mm offset with Neuspeed Sport springs and they do not rub.
Old Feb 29, 2004
sf2ryu's Avatar
Rei, what kind of springs do you have? How much drop?
Old Feb 29, 2004
ssm pimp mobile's Avatar
ssm pimp mobile is an unknown quantity at this point
i have goldline springs on my sedan..i have 205-45-17 falkens...i had to roll my back fender inorder to adjust my camber right....i am tucking in the back ..i think you could fit it..u might just have to roll your back fenders though...
JOHN
Old Mar 1, 2004
Cocky's Avatar
Cocky guys kick ass!
i got Eibach, 2" front, 2 1/4" back drop.. same size tires.. and i haven't rubbed once, and i've had 6 people in my car. i rubbed before i dropped it, but not since. :P
Old Mar 2, 2004
flotsamm's Avatar
What Eibach springs do you have? The Prokit only drops about 1" and the Sportlines are about 1.4" according to Eibach.
Old Mar 2, 2004
sw388integra's Avatar
no rubby, don't worry
Old Mar 3, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
I scrubbed BAD when i lowered. I went about 2-2.25" or so, on my Tein SS and couldnt even drive it, cause i didnt wanna raise it up.
I went out the next day and bought new Yoko's in 205/40/17 and then cut out a small amount of my real fender and rolled it (had all done at shop).
BECAREFUL! Everyone told me Id be fine, etc. and I was definately not.....It sucked ***.
Old Mar 3, 2004
slicksivik's Avatar
i dunno about what u got, but i got some 215/45/17 and i just put them on and i look down above my rims and i can see the tire from straight above the fender. they stick out a few mm. If i were to lower my car, theyd be ripping up my fender for sure. I dunno whether its just my motegi mr7's cuz they have spacers on them or waht, but i dont think im dropping. there pretty snug at regular height cuz there like maybe 1.75 or so from the fender. thats room for bumps and all. the body kit adds some length so it keeps it snugger looking then plain stock. the body kit kinda curves so taht worrys me on top, but i might drop. i'd definitelly need wide fenders or like an inch rolled. seriously...
Old Mar 6, 2004
sf2ryu's Avatar
Cool
When I bought my rims (Eagle Alloy 193s) I went with the 215/45/17 tires because I didn't plan on lowering, and the profile of the tire didn't look that bad to me (this wheel/tire config looked good on stock IS300s). The gap doesn't bother me much, but as I keep looking at the car it seems like it would look better slammed, plus help with cornering. Maybe I shoulda went with 205/40/17 tires and I wouldn't have run into this issue. Now I'm curious to find out what the offset of my rims are...
Old Mar 6, 2004
sf2ryu's Avatar
Wink
Just found out the offset of my Eagle 193 rims. They are 17 x 7 with a 40mm offset. Are 40mm offset wheels more prone to rubbing?
Old Mar 6, 2004
rei846's Avatar
my drop is around 1.5-1.75. i had some 17 velox and the offset was 40 and they rubbed. somebody said anything 42+ is good. but, i know for sure 45 offset does not rub with neuspeed sport springs.
Old Mar 7, 2004
greeot's Avatar
greeot is an unknown quantity at this point
you were rubbing before you lowered it and now you don't?
i don't know man, i've got the same wheel size and haven't rubbed once-- with no drop or now with h&r's with 1.3" front and 1.5" back...
alxz310
Jul 30, 2015 12:18 PM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
