tyre for 17" x 7 38mm offset
Old Feb 17, 2004
alvinz's Avatar
alvinz is an unknown quantity at this point
Hi guys,
I'm about to buy a set of wheels. They're 17 x 7 and have 38mm offset, deepdish.
My question is what's the best tyre size? My car is civic 2001 sedan, and I'll have it dropped super low.
Will 215/45 rub? or should I go for 215/40? Any other suggestion?
Thanks a lot.
Alvin
Old Feb 17, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Define superlow.
Honestly I think you're going to have issues no matter what tire you choose if its slammed. I'm running +37 offsets with 215/45/17, it needs a 3 finger gap to clear the fender lips. I guess you can gauge it from there.
Old Feb 17, 2004
alvinz's Avatar
Thanks
So, offset 38mm is not good for lowering.
Will 205/40/17 help? What's the standard offset from factory? My car use 14" and it's not an alloy wheel.
Cheers.
Old Feb 17, 2004
alvinz's Avatar
Superlow = 1 finger between tyre and fender lip.
extreme low = tyre is inside
Old Feb 17, 2004
666's Avatar
666
666 is an unknown quantity at this point
Those will for sure rub on your fender, with a +38mm offset the tire and wheel will be even with the outside of the fender...not good. My suggestion is to find a wheel with a +42mm to +45mm offset then you can safley run a 205/45-17 tire and have your speedometer read correctly.
Old Feb 18, 2004
alvinz's Avatar
Thanks for your suggestion. Lucky I haven't bought those wheels.
Too bad.. I like the deep dish style though. Is there any deep dish with offset 42mm?
Old Feb 18, 2004
666's Avatar
666
Axis offers a WheelsiteMesh 2 wheel that has around a 2" lip depending on size, try looking into those.
UltraHDGames
Jun 8, 2016 05:16 PM
alvinecigs
Air Conditioning
120
Sep 20, 2015 03:47 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
naokigoffi
Aug 30, 2015 06:19 PM
