Help with ...vibration @ high speeds!
Old Feb 6, 2004
604SPEEDANDSTYLE's Avatar
604SPEEDANDSTYLE is an unknown quantity at this point
Unhappy Help with ...vibration @ high speeds!
not sure what the problem is but,,, i recently upgraded my stock wheels n tires too
15" inch Falken ziex 60/195 mounted on 2000 SIR wheels
everything is fine...i love the handling BUT,....when i go over 150 on the highway it starts vibrating a bit...i took it back to sears..because they did all the mounting to begin with. So they basically switched all the tires around (rotated them) and now the shake is comming from the back wheels...and not the front...ive chekced the wheels and they are TRUE. no bends or damage or curbs whatsoever...the wheels are all torqued down properly...im not sure whats causing this...and the alignment is perfect! it started happening once i changed from my stock wheels/tires to these... do i need hubcentric rings or something? someone plz help me!!!!
Old Feb 7, 2004
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
?! did they check the balance again? and 150 on the highway? you go pretty fast!
Old Feb 7, 2004
tfnaaf's Avatar
BLDNPSI Mod
sounds like a balance or tire out of round issue
Old Feb 7, 2004
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
^^I agree
Old Feb 7, 2004
yeah they checked the balance also...still not sure whats makin it vibrate
and yah..150 km\hr so thats like 90mph... thats not that fast.
Old Feb 7, 2004
Same thing happens to me. You need to get a wheel ALIGNMENT. It's different from balancing the tires. Basically it's to make sure the wheels are parallel with the car. I'm waiting until spring when I get new tires to do it.
Old Feb 7, 2004
Jodster's Avatar
Post Whore General
^^^^^^Yup that will fix it.
Old Feb 7, 2004
tfnaaf's Avatar
BLDNPSI Mod
wheel alignment doesn't follow tire rotation its not the alignment, you have either a tire out of balance, bent wheel, or out of round tire. Not to mention VIBRATION is caused from something out of balance, out of round, or no loger at a 90` to the axis( bent wheel ) Wheel alignment can NOT cause vibration, well not direct anyways.
cukaracha
30
Jul 26, 2015 12:01 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
silentz
Jul 9, 2015 08:16 PM
CivicsClass101
Jul 9, 2015 11:14 AM
