tire sizes
Old Feb 1, 2004
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
tire sizes
hey i got the rims that i'm getting.. or rather picked them out, but i was wondering if i should upgrade the tires... the tires that comes with the rims are (205/40/17)... should i upgrade them to the next level (215/45/17)???? will it make that much of a difference??
Old Feb 1, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
yes; 215/45R17 is the closest to the stock overall diameter, and therefore you will not mess up either your spedometer, odometer, OR gear ratios. Also, your rims will be slightly better protected from ruts and the like by the 215/45.
Old Feb 1, 2004
but what if i want some low profile tires?? i mean dang, i don't want that much tire really.. i live in detroit.. should i really get the 215 tire???
Old Feb 1, 2004
jwalker87's Avatar
Bodacious Member
its still very slim; if you look at the member's rides, the vast majority of people here have 215/45, because its closer to stock size and still very low prifile.
Old Feb 1, 2004
ok damn i really dont' know what to do.. it's like i do love my low profile tire look.. but then ya'll keep saying to get the 215, on the rim... damn
Old Feb 1, 2004
greynotch's Avatar
greynotch is an unknown quantity at this point
If you are going from a 205/40 R17 to a bigger tire, it should be either 215/40 R17 or 225/35 R17.
I don't think that 10mm wider will be worth the investment. Howeverm you WILL see a noticable difference between a 205mm and a 225mm.
To keep the speedo correct, if you upgrade to a wider tire, then the profile should be lower, not higher. Otherwise, they'll be wider AND fatter.
Old Feb 1, 2004
jwalker87's Avatar
Bodacious Member
215/45R17 is pretty much the defacto standard tire size for our car; you want to keep the speedo accurate, and this size is THE closest you can get for a 17" wheel.
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
