Will 56.1 work?
Old Jan 23, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Will 56.1 work?
I ordered some hub centeric rings from discount tire. I called in and the salesman said they only had 56.1 mm, what ive seen from searching is that the inside for our civic should be 56.15. But i mean .05 mm is pretty small. Anyone know if this will still fit?
Old Jan 23, 2004
slicksivik's Avatar
each rim has a specific hub centric ring and size. i dont even think stock tires have a hub centric ring.
Old Jan 23, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
You shouldn't have an issue. If you do, you can take a pad of scotch brite and clear out .05 mm (about .0185")
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
