19's with sportline
Old Dec 28, 2003
LITTLELOUIE's Avatar
LITTLELOUIE is an unknown quantity at this point
19's with sportline
Can I put 19" inch wheels with 215/35/19 with the eibach sportlines or should I swap them out for the pro kit
Old Dec 28, 2003
civicvtec1ps's Avatar
Search and Learn
Swap with pro kit. Eibach sportlines are too low with 215/35/19.
Old Dec 28, 2003
666's Avatar
666
666 is an unknown quantity at this point
Same here, it may work but you are going to run the risk of rubbing.
Old Dec 28, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
nah, dont worry u cna go as low as 2.7 w/ 215/35/19 pirelli p7000 19x7.5 +44 offset......+45 u can go .1 lower..... and if u got BF goodrich/p-zeronero/nitto or any toyo(225/35 u can only go about 2.4 because their wider at top..^^^^ all of this is with rear fender rolled
riley
i know from experience...:-D
what kinda 19's u getting axis rims r 19x8 +45 just so u know and u can go low but idk....
i wouold also reccomentd stuff shocks.. koni or better. u need stiff, stiffer is better just like with ur girlfriend ;-)
Old Dec 29, 2003
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
I have 19's and rubbed with the sportlines, I switched to the prokit and been cool since
Old Dec 30, 2003
ooshoe's Avatar
ooshoe is an unknown quantity at this point
will 17s rub with sportline???
Old Dec 30, 2003
Search and Learn
Depends on offset of wheels, tire Size...
Most likely you will be fine. I had about 2" drop with 215/45/17. Wheels offset is 43. I didnt have any rubbing issues.
Old Dec 30, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
i'd do it just for being unique....
StealthCivic
32
Jul 16, 2002 04:06 PM
WishIWaitedForRSX
Jul 5, 2002 12:01 PM
ScottieEX
Jun 3, 2002 06:36 PM
Ramen
Apr 11, 2002 01:48 AM
RunawaySoul
Apr 1, 2002 07:56 PM
