Adding Rims to my civic, how will this affect it?
Old Dec 19, 2003
03civsilv30's Avatar
03civsilv30 is an unknown quantity at this point
Im adding 225/45/17 to my civic and on the tire calculator page it says that this compared to factory equipped tires is 1.93% too SLOW what effect will this have on my car besides my speedometer reading that percent slower than im actually going???
I saw another topic (is it my wheels or my civic?) where the guy said w/his rims he was getting horrible gas mileage but his car was 3.25% too FAST
if he was too fast and im coming up short whats the opposite effect of his poor gas mileage??? improved mileage????
also i was contemplating 215's which w/the calculator says its only .64% slower. am i better of w/these just since its closer to factory gear/ratio and gas mileage
thanks anyone for the help
Old Dec 19, 2003
666's Avatar
666
666 is an unknown quantity at this point
Yes, you are better off with the 215/45-17's and check your PM's.
Old Dec 19, 2003
HondaLuver's Avatar
Its a celebration bitches!
215/45/17, i think 215/40/17 will look better...
Old Dec 20, 2003
yea i was thinkin that that 40's would look sweet but then i was concerned with losing comfortability. wont the ride be noticeable different?
Old Dec 20, 2003
666's Avatar
666
A little, it will still be stiff but not as bad with the 45 sidewall. You can always move up to 18's too, that will fill up the fender well nicely, and use a 215/40-18 tire.
Old Dec 20, 2003
i would but i got 17 limix wheels
Old Dec 20, 2003
666's Avatar
666
To be quite honest with you I had 17" rims with Nitto NT-555 205/40-17 tires on my 7th gen EX coupe before I bought my 18-inchers.(they were from my 6th gen coupe) The tire is definately way too small of a sidewall with out a drop or in some cases even with a drop. It looks kinda odd actually. I think you will be happy with the 215/45-17's though, you will have an accurate speedometer reading, accurate milage reading, and a less of a chance of denting a rim on a pothole or bump with the extra sidewall. It won't look that bad.
Old Dec 20, 2003
If you get bigger rims, your acceleration will go down from the added weight and rotational mass. The ride will also be bumpier.
Old Dec 20, 2003
greeot's Avatar
greeot is an unknown quantity at this point
if you go with 205/40/17, the ride will be noticeably stiffer and bumpier. i guess it's a personal preference but i like stiffness as opposed to the smoother factory feel...
Old Jan 5, 2004
well i think im gonna get the 215/45/17's just for the comfort... see how it is... that is soon as i get the loot.
I was checking out some on tires.com and found some yokohama avs es100's think i like them or the nitto nt neogen anybody heard anything bout these???
Old Jan 6, 2004
XxJDMCivicxX's Avatar
205-40-17 imo is too thin if your not gonna drop it, 215-45-17 doesn't look all that bad if you leave it at stock height.
Old Jan 8, 2004
Enijade's Avatar
Enijade is an unknown quantity at this point
Whatup People! Would anybody know if I did get the 215/40/18 rims & tires, how much of a drop should I do in order to complete the look?
Old Jan 8, 2004
doubledeuce2k2's Avatar
welcome to the forums. i don't think you can do much more than an inch drop on 18's without rubbing issues.
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
alexkharden
Apr 23, 2015 07:13 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
