good calipers and rotors? where?
i was kinda hoping to find something different than a big brake kit. possibly just some slotted rotors and performance calipers, if there are any. i think i read somewhre that the big brake kits need a 16 inch rim for them to fit. i only have a 15 inch.
thanks,
chris
thanks,
chris
call stainless steel brake company and ask what they have. all the other companies probably have calipers with OEM sized slotted rotors. YOu have to call and ask.
Hail to the king baby
your best bet is to get some slotted rotors and the green brake pads used with stock calipers.
they will wear down faster than stock but not as fast as cross drilled big brake kit.
get some sttel braded brake lines to keep a stiff pedal pressure. Also, you may just want to
find the back disks off a Si and swap those for your drums...good luck
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
