Rotor refinish necessary?
Old Aug 14, 2003
odie's Avatar
odie is an unknown quantity at this point
One of the discs on my front brakes has a very thin (1mm wide)
groove that is concentric to the shape of the disc.
Do I need to have the rotor refinished? Can such a groove
actually affect my brake performance? In my opinion, the
would barely change the amount of surface area with which
the pad contacts the disc.
Please advise...
Old Aug 14, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
If you brakes feel normal and are not vibrating, no need to do anything.
Old Aug 14, 2003
djmota's Avatar
the groove will get worse or multiply with time and cause your brakes to squeek. you can either spend a little now and fix it or a bit more later replacing the bad rotor
Old Aug 14, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
How much to have the rotor refinished?
Old Aug 14, 2003
Ronin's Avatar
If you take off the rotors yourself and take them to a shop, it's around $10 per rotor. If you get a garage to do everything including dismantling and reinstalling, then anywhere from $50-$100 depending on their labor.
But like I said, if you don't feel or hear anything out of the ordinary, it may not be worth the time and money to get them resurfaced ... especially if you get them to do the entire job. I mean, you can get brand new Brembo blanks for $35-$40 each... and even lower if you search around.
Also, if the groove is very minor, you may be cutting down your rotors for no reason.
Old Aug 15, 2003
All Eyes On Z
I have a groove on my front left disc... you can only hear it when the car is cold and braking in reverse. I use the e-brake instead sometimes.
SammySC
121
Apr 7, 2017 07:43 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
