brake question
Old Jul 24, 2003
AntDeezy's Avatar
brake question
if I buy the AEM big brake kit for the front, i know that they use the oem calipers and new AEM rotors etc.
question is:
can I use the oem front discs in the back, I believe it could be done with the correct mounting brackets.... am I wrong, can this be easily done ?
BTW if this is a re-post
Old Jul 24, 2003
Green Civic's Avatar
I dont think so. I think red is trying to use the 2002 SI rear big disk brake kit to make rear disk brakes for his car. I think you need to talk to a mechanic more than me though.
Old Jul 24, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
anything can be done with money right?
The fronts are vented, the rears would be solid discs. So you'd need to somehow jimmyrig a front caliper on there to work since the rear would be smaller. It's not worth the trouble to do all that, you'd still need the calipers, which are most of the cost involved in the swap. So you might as well just do it the right way with a set of rears.
Old Jul 29, 2003
AntDeezy's Avatar
rear Calipers from an SI
front EX disc
i think the discs are the same from the SI rear and the EX front ...
if so this should work right ?
Old Jul 29, 2003
Jap-Euro Fusion
They're not the same. The fronts are vented and the rears are solid. The EX and Si front brakes are completely identical. 10.3 Vented up front, 10.2 Solid in the rear. The Rear brakes are a lot skinnier than the fronts. You need the rear disc and caliper.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
