Change rotors = alignment?
Old Jul 22, 2003
taz757's Avatar
Question Change rotors = alignment?
I'm just a little confused I guess about changing out my rotors. I know that it's going to be relatively easy to do, but I'm just wondering if I'm going to need an alignment afterwards? It would make sense to me as you're pretty much going to be taking apart your whole front end to change the rotors. What has been your guys experience in this?
Old Jul 22, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
You don't need an alignment when switching rotors. If you feel something is not right afterwards, it's probably something that went wrong during the installation, not an alignment problem.
And you don't need to take apart the whole front end just for rotors : take off the wheels, take off the brakes, take off the rotors. Grey's got a nice DIY for this... check the DIY section.
Old Jul 23, 2003
Grey's Avatar
DIY King
The only thing that used to be done was a machining of the surface of the rotor to be true to the rotational plane. This way you don't get uneven brake pad wear and what not. Although I don't think many people get their new rotors turned these days. I guess manufacturing tolerances are pretty tight now.
Old Jul 24, 2003
Ronin's Avatar
Actually, most Honda dealerships will turn brand new rotors on installation. And they ONLY use the "on-car" rotor lathe... i.e., the portable lathe machine that you hook up to the rotor to lathe it, AFTER the rotor is installed. Apparently, this gives you a truer resurfacing than traditional lathe machines.
My dealership told me that for some reason, Hondas are very sensitive to brake vibration if you don't "true" the new rotors to the car.
civicowner123
Jul 24, 2015 10:02 PM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
