one tough cookie
Old Jul 15, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
one tough cookie
i tried to remove the bolts holding my caliper on today. those bolts are so tight! i tried spraying them down with some wd-40 with no luck. i might have to use my air compressor and impact wrench!
i think my pads need some grease. they're squeaking. stupid previous owner didn't take care of this baby like she deserves!
Old Jul 15, 2003
GabberHead's Avatar
GabberHead is an unknown quantity at this point
Someone needs to go to the gym.
Well, either that or get a cheater/breaker bar.
Now... those dang screws holding on the rotors.. I soaked those suckers with rust breaker for 20 min and they still wouldn't come off.
Old Jul 15, 2003
HondaLuver's Avatar
Its a celebration bitches!
buy a torque wrench!!! get new pads also
Old Jul 16, 2003
Skunk2ner's Avatar
what does a torque wrench have to do with getting a tight bolt loose? if you use a torque wrench to loosen a tight bolt, you're crazy! you'll ruin an expensive wrench.... i have one, but i'd only use it to tighten, never to loosen.
i might need new pads, i wanted to pull them off to inspect them, but no luck today.
i probably should hit the gym, but i'm not a weak person, i used to lift weights a lot. they're just on there tight! thats what happens when you take your car in for brakes at a place with idiot mechanics that use an impact wrench to tighten bolts.
CarStuff
Dec 6, 2020 12:52 PM
sccarally
Texas
Sep 27, 2015 03:33 PM
Bikergofast
Sep 12, 2015 01:36 PM
iluvbritney
16
Feb 7, 2003 01:51 AM
